  New Posts New Posts RSS Feed - So are there any good DIY designs?
Requiem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Requiem Quote  Post ReplyReply Direct Link To This Post Topic: So are there any good DIY designs?
    Posted: 19 January 2023 at 8:05am
The plans for the WSX sub are widely available and they run really well with the standard Void V18. They sound great. Not sure if you would call it a DIY design as originally Martin Audio but its available for anyone to build due to its age.
Hog scoops, as mentioned, are pretty impressive. I dont particularly like the muddy bass of them but for sheer output they are hard to beat with many other DIY bins.
Punishers are pretty awesome for the size, a one man lift and have a real high output for a single 12" sub.
Invaders too, are pretty good. maybe not the best but I like them
Even G-subs have a really high output and sound nice, but are better for indoor venues and not very good at outdoor or covering large crowds. Everyone slates reflex but I think thats just because they are 'boring' builds, you cant go wrong with a good reflex rig up close.
As for upper bass, the USB or the ES18 are pretty good cabs.
Tops, I have a soft spot for Xtro's but if you want ease of build and loading then the MT121 does the job great.
All have their downsides obviously as does any cab but cant really go wrong with those if they are loaded, set up and powered properly.
Edited by Requiem - 19 January 2023 at 8:06am
www.requiem-soundsystem.com
Custom Martin Audio WSX, USB & CSG Soundsystem based in Bristol
Meat Substitute View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Substitute Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2023 at 7:51am
I had Omnitop12s. The idea was great, the size was great, the weight was highly convenient. Just a shame about the sound.
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2023 at 10:07pm
what was the verdict on bill fitzmaurice designs? i know a few ppl who run his cabs and rate them, but i don’t know the circumstances of them getting hold of them
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2023 at 8:51am
Also add the DIYRM (Scott Hinson) to the list. Has various designs for PA and home available on his FB page with extended pdf's on them.
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2023 at 7:51am
Hogs obviously , after all these years hearing them rumble still makes me excited Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2023 at 7:22am
it’s not really a plan as it’s a copy…
but plans do exist…
a copy of the Ws218X ;)
does that count!?
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2023 at 2:14pm
I'm amazed no one has mentioned the PM90 yet..... 🤔
JamesH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JamesH Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2023 at 12:28pm
The B&C double 18 6thOrder bandpass is superb
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Substitute Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2023 at 10:33am
Of the designs on here I have to say I have a soft spot for the X1 sub. It's pretty old now but they really do drop with proper drivers and amps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2023 at 10:06am
@JonB67
They are good, same goes for the newer B&C designs.
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2023 at 9:17am
There's a load of designs on the 18sound website. Couldnt find much feedback on them online so no idea if they're any good!?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2023 at 10:54am
I - (ok - my carpenter Smile) built a couple of (slightly) modified SMT212's. Loaded with P-Audio SN 12B's & BM-D750's. Still going strong & really great sounding cab.
I also have a single Cubo 18, loaded with an 18 Sound 18LW800, that I picked up with a job lot ages ago. Unfortunately, just the 1, but I take it out occasionally for small events. I do like the sensitivity of the cab. It doesn't need 1000's of watts to drive the thing.   LOL
