MC2 1250 vs 2 * QSC 3602 |
yodominic ![]() Young Croc ![]() ![]() Joined: 18 December 2008 Location: London Status: Offline Points: 701 |
![]() ![]() ![]() ![]() ![]() Posted: 23 January 2023 at 7:31pm |
Many thanks for all your thoughts, I also have a Lab FP3400 which I believe will be better at 2 ohms compared to QSC and MC2, any thoughts on this
levyte357- ![]() Old Croc ![]() ![]() Joined: 27 July 2012 Location: UK, South East Status: Online Points: 7959 |
You are right there, but it is the later grey plx, that people don't rate. In my experience, the CX are much more sturdy. Was thinking of getting PLX1602, for home hifi, as they are cheap and Class AB iirc.
Djdarch ![]() Old Croc ![]() ![]() Joined: 10 November 2005 Location: Newark, Notts Status: Offline Points: 1987 |
Im sure the cx series and the PLX series are the same , only the CX is install specific and then the PLX is the touring version .
The "02" version of the PLX is the original ? Im sure its just refers to 3602 3600 watts at 2 ohm . the "04" were made to put the power in at 4 ohms but couldn't handle 2 ohm loads .PLX 1804 1800 watts at 4 ohm ( 900 per channel). That's my take on it . as per the OP initial question, like others have said suck it and see , especially seeing as you already own the amps .
lickweed ![]() Old Croc ![]() Joined: 02 May 2009 Location: leyton Status: Offline Points: 2454 |
Country in which last significant manufacturing process was carried out
http://www.liquidsound.co.uk/
The original PLX series, were generally quite OK, if not used on sub, and kept clean/serviced. Completely avoided PLX '02 series, and PL2 series. Was then advised to upgrade to CX series, best decision ever made, only issue being CX1102 being biggest unit. PL4 has power, but gets hot, never tried PL340. Would definitely prefer Admark/CVR 4x channel for mids, compared to PLX 3602. |
kedwardsleisure ![]() Old Croc ![]() Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4794 |
I think 'made in the usa' on a PLX means the chinese pcb has its heatsinks bolted on in the usa and then placed n the chinese case.
North Staffordshire |
This is the only time (I think), in a couple of decades, I have to disagree with the right honorable, kedwards.. ![]() ![]() Edited by levyte357- - 21 January 2023 at 2:15pm |
JamesH ![]() Registered User ![]() Joined: 24 August 2022 Status: Offline Points: 54 |
Yup, my 3602 has "Made in USA" on back.
Is it one of those, "components made in China, part assembled, finished in US" things then? |
Strange , how come they write made in usa on plx3602 then.
The MC1250 is a pretty reliable if old bit of british-made kit, engineered for quality rather than cost, IMHO. It has a variable impedance power supply a but like a crown VZ supply....except it is not automatic. You get to select the 'VZ' mode by a switch on the back. This connects the transformer windings either in parallel for high current low voltage or in series for high voltage low current, all by a microprocessor controlled relay.
I'm not sure how it would perform on a low impedance but high voltage requirement of a bunch of parallel-connected mid-highs, I think you'd have to take the specs with a pinch of salt and just try it. The PLX3602 is a quality chinese-built (by Gold-Peak) machine and a tad more modern than the MC2 but like all the range they will go bang if left dirty, damp or hot. If it's not a new one, get it blown out with an airline and check the mods have all been done before torturing it! |
Only other Amp we have in our possession is a Lab FP 3400. We are looking to drive 4 mid cabs rated at 1000@4ohms
Edited by yodominic - 20 January 2023 at 11:28pm |
Interesting lesson..
Couple of years ago, put rig in an install, with mid highs = ASS MX600s (16 ohm 2", 2x12" 16ohm), with QSC CX702 on 2", QSC PL4 on 12s. Initial set with 1x mid top per side, with intention of adding another cab per side, when moving to larger room in venue. Sounded OK. Put PL380 on 12" section, and the PL4 on the 2" cabs. All of a sudden, huge increase in perceived low mid/mid frequencies, requiring cutting eq, where we previously had boost, and extra overhead, brought increase in perceived sound quality. Was not the obvious increase in SPL from more power, that was impressive, was the increase at certain frequencies, that previously had to be boosted.
Edited by levyte357- - 20 January 2023 at 1:22pm |
