CVR and Admark Amps |
Page 123 8> |
tehuti ![]() New Member ![]() Joined: 24 March 2010 Status: Offline Points: 8 |
![]() ![]() ![]() ![]() ![]() Posted: 13 August 2023 at 5:01am |
I am talking about this comment about the ad442 specifically .
Requiem ![]() Old Croc ![]() ![]() Joined: 20 January 2011 Location: Bristol Status: Offline Points: 1795 |
What do you mean by not the best sound?
When we compared them to MC2 E-series, Powersoft K series, Linea Research and FFA the difference was negligable. The only one that smashed all of the others out of the park was the MC2 Delta series and that seemed to be way better than all of the other amps we tested, with the same signal on the same box in the same position with the same gain. |
www.requiem-soundsystem.com
Custom Martin Audio WSX, USB & CSG Soundsystem based in Bristol |
Can you find this info? I bought 2x ad442 for backup amps etc and they worked so far on low mids and bass but not the best sound. Worried to use them or sell them somehow or keep for emergencies. Do the other admark amps work fine without any anomolies?
levyte357- ![]() Old Croc ![]() ![]() Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8079 |
Did you buy it for sub, or mid tops. |
MarjanM ![]() Old Croc ![]() ![]() Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7735 |
Please report you finding. 442 looks too good to be true.
lickweed ![]() Old Croc ![]() Joined: 02 May 2009 Location: leyton Status: Offline Points: 2481 |
yes , ad442 , didn't have a chance to use it in anger yet.
http://www.liquidsound.co.uk/
Viktor , we know only good amp is a PKN , but its getting a bit boring.
Admarks sounds rather good to my ears
Do you mean the Admark ad442? I was curious about this model if you have comparisons between that and the other models I’m very curious .
U.Viktor ![]() Young Croc ![]() Joined: 04 May 2010 Status: Offline Points: 716 |
There is even a GaN-transistor based version with 520VDC rails (2* 260V or so) However the sound quality is exceptionally poor.. There is 'ALLDSP' inside which is also ruins sound quality. It it not reach any of the professional grade performance. We were unable to determine what makes the sound quality so bad but If you take an oscilloscope the waveforms on the output are very ugly. I have pictures somewhere, let me find them and show.. Horrible in every audio meanings :-)
I asked quite a lot of questions about amps , before i pulled a triger( bought some)Thanks Stef.
Its by no means Armonia , Lake or any other pro environment , but its ok , there is even some FIR . They can and do higher end of spectrum , but i don't think they sell a lot , its well established market . |
smitske96 ![]() Young Croc ![]() Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1035 |
@Marjan
its indeed AllDSP (SBD44). It works ok. Fast but very simple UI, and for me personally not enough capabilities processing wise. The LCD of the amp is also quite limited I now run some CVR 3004 DSP which are basically the same amp as the AD430 with a different DSP and some other small tweaks. Its the same DSP as used in the wharfdale DP-F series. I am not sure which manufacturer makes the DSP, but its looks nice and works nice.
How do you like the DSP? Is it AllDSP inside?
Page 123 8> |
