Admark Dsp setup (All-dsp, ALLCONTROL) |
T Willy ![]() Registered User ![]() ![]() Joined: 07 February 2022 Location: Wisconsin Status: Offline Points: 43 |
![]() ![]() ![]() ![]() ![]() Posted: 25 July 2023 at 4:47am |
Ive ran into this same issue. Go to the hardware tab > configuration > advanced configuration and wait for it to load. Then go to output configuration tab. Adjust the amplifier channel gain until the limiter reaches the RMS of the amplifier when maxed out. The other gain on that screen controls the limiters in the compressor menu. I dont think this is correct, but it works. Without knowing the channel gain from the manufacturer makes it difficult.
Char543 ![]() Registered User ![]() Joined: 14 September 2016 Location: Inside a sub Status: Offline Points: 11 |
Just got a k420dsp (4x3400w @4r) and trying to setup the limiters on it. It uses the SBD44 board from alldsp.
Peak limiter release can only go upto 100ms in the ALLCONTROL software. Sure I read something about it on here being a representative error - it just displays the wrong number but I can’t find anything now… Setting rms output compressor/ limiter, the threshold goes upto 9Vrms im the dsp software, I think I should be aiming for somewhere around 10x that. Anyone have any experience with or documentation for programming the sbd44? Thanks!
Edit: here is a link to the manual for the device 'https://alldsp-oem.com/wp-content/downloads/downloads/AllDSP%20ALLControl%20User%20Manual.pdf' it says there, that the value is in dB/s db per second rise but software looks different on my end Edited by Char543 - 18 May 2023 at 7:17pm |
