HD15 with speaker waffle grills? |
piers1
Joined: 02 February 2011 Status: Offline Points: 40 |
Topic: HD15 with speaker waffle grills?Posted: 08 June 2023 at 1:44pm |
Anyone tried HD15 with heavy-duty speaker waffle grills? Installed with rubber mounting gaskets on the front of the driver. Will it be a tight and vibration proof?
Edited by piers1 - 08 June 2023 at 1:46pm |
Esc4pe
Joined: 08 August 2021 Location: England Status: Offline Points: 167 |
Posted: 08 June 2023 at 2:10pm |
HD15 does not have an exposed driver?
piers1
Posted: 08 June 2023 at 2:15pm |
That is correct, but you can reach the driver trough the horn. The HD15 is in perfect height for that, in middle of my stack. |
APW
Joined: 13 November 2012 Location: UK Status: Offline Points: 1234 |
Posted: 08 June 2023 at 5:49pm |
Put a full grill on the front or a smaller grill down the horn near the brace. i.e. like the EAW LA400.... if you are in the UK PM Markie, he is the forums goto guy for custom grills:
Edited by APW - 08 June 2023 at 5:50pm |
piers1
Posted: 08 June 2023 at 9:39pm |
Thanks for the info. I would like to hear from HD15 owners, if anyone have, an experience with the grills mounted direct on front of the driver. |
cravings
Joined: 30 January 2007 Location: Ireland Status: Online Points: 7507 |
Posted: 08 June 2023 at 9:57pm |
markie has pretty much retired from grill making.
I don't think they're necessary for hd15s. |
piers1
Posted: 09 June 2023 at 4:11am |
Grills are not “optional” after damaged drivers. |
cravings
Posted: 09 June 2023 at 6:44am |
has it happened? I have run similar turbosound bins for many years now and never had someone reach all the way in to damage a driver.
clamps |
bob4
Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1924 |
Posted: 09 June 2023 at 9:18am |
Do you mean installing such a grill on the inside of the baffle, between driver and baffle? Personally wouldn't do that. Someone malicious cojld still use a screwdriver or pencil or knitting needle to poke through the gaps of the grill.
Better install a grill at the throat, as indicated in the picture. This will most efficiently prevent anyone from getting near the driver to damage it. And you will not have the risk of your cone or suspension hitting the grill. ![]() |
piers1
Posted: 09 June 2023 at 12:40pm |
Yes, preferably grill on the inside of the baffle and driver. But regardless of the grill position, I am more interested to hear if anyone out there have grills on HD15’s, if so what is the experience in regards vibrations and sound? Edited by piers1 - 09 June 2023 at 12:58pm |
piers1
Posted: 09 June 2023 at 12:45pm |
Most Turbo’s are a bit deeper than a HD15’s.
Just enough, to reach a driver harder. Edited by piers1 - 09 June 2023 at 1:01pm |
