  New Posts New Posts RSS Feed - Admark CD8000
Admark CD8000
turbo7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote turbo7 Quote  Post ReplyReply Direct Link To This Post Topic: Admark CD8000
    Posted: 16 September 2023 at 12:25pm
Originally posted by yodominic yodominic wrote:
Hi All
I’ve been offered an Admark CD8000 amp, it’s a 4 Channel amp but I’m hoping to drive a 2 * dual 18’’ loaded cabs. Has anyone used these amps and your experience and reliability issues is much appreciated
Thanks
Just don't expect the amplifier, to output quoted specs.
Even with the most respected makes of these amps, I would only expect max 50% of rated output power, in 40hz-100hz range.
Remember even the illustrious Powersoft X8, is not recommended for sub usage, on every channel.
Exactly this !
dlyxover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2023 at 8:44am
I have a SAE PQM13 and PCM18, have been running both a 4ohm with no issues for the last 8 years.
I have a Sinbosen fp20000Q incoming in the next few weeks, claims to produce 4x4K at 4ohm
Will be interesting to see how its stands up.
yodominic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yodominic Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2023 at 8:13pm
is the same design the SAE PQM13 but better build quality than the current SAE amps.
Not an expert in Chinese amps but if they are SAE equivalent then it should be decent enough, price wise how much are they worth
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2023 at 7:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote yodominic Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2023 at 7:06pm
I’m trying to get 4 - 5K per side into 4ohm, 2 channels driven. Not sure how good these amp are, their delivery of stated power and reliability too
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2023 at 6:56pm
So its not admark. But those are nice amps if i have to believe most.
Also Ben and Marjan (mm acoustics) which is the same amp (correct me if i'm wrong) are using/selling those. Both know about what they are talking, and them using those same amps should say enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yodominic Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2023 at 6:25pm
Hi All, managed to get more info from the guys selling it as he’s too slow to respond, it’s the CD8000
Just to add, apparently it can be run as a 2 channel amp too, probably with dip switches at the back. Has anyone used these amps or heard of these
Edited by yodominic - 15 September 2023 at 6:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote yodominic Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2023 at 11:39pm
Will get this uploaded soon, waiting for the pic
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2023 at 2:04pm
Thanks for all your replies, I personally don’t have good experience with Chinese 4 channel amps and only wants to run 1 Pair of dual 18 loaded subs on this amp.
Is it best to get them wired so 1 driver per channel or just use the 2 channels of the amp
Thanks
From what I've been told, feedback received, Admark K35, AD42, (2 Channel amps), will do this with ease.
Not had any feedback, on Zenith branded amps.
knet94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2023 at 2:03pm
Thanks
One driver per amp channel would give the amp a very easy life. Been doing it for years with some of my double 18" and my double 21" bins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2023 at 2:01pm
@yodominic, do you have any pics of this elusive beast?
Post Options Post Options   Thanks (0) Thanks(0)   Quote yodominic Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2023 at 12:52pm
Thanks
This page was generated in 0.139 seconds.
