  New Posts New Posts RSS Feed - 18" BR 18XL2000
18" BR 18XL2000
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Topic: 18" BR 18XL2000
    Posted: 10 April 2024 at 11:17pm
Edited by smitske96 - 10 April 2024 at 11:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 10 April 2024 at 8:33pm
Originally posted by smitske96 smitske96 wrote:
How do you find the DSP on those? I got few amp plates to test and they just sit there on the shelv for years now. Horrible DSP.
 but finding a suitable DSP that can be bought by less then hundreds has been quite impossible.
A search for the holly grail at the moment even for way more than hundreds.
i am working on developing our own one because the search have proven futile.
It is such an oportunity for someone that can fill the void but no one seems be grabbing the opportunity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 10 April 2024 at 3:27pm
I have had two previous converters before using the OMB one and the OMB one did the job. Not the best DSP, but seeing what is available for consumers, not much choice.
The amp modules themselves are quite ok, and for me enough choice regarding size, channel and power options. I would be fine with designing an own plate etc, but finding a suitable DSP that can be bought by less then hundreds has been quite impossible.
Edited by smitske96 - 10 April 2024 at 3:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 10 April 2024 at 12:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 10 April 2024 at 11:06am
Originally posted by VECTORDJ VECTORDJ wrote:
Hi, What Plate Amp did You use???? Thanx, Vectordj
They are from OMB audio.
VECTORDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VECTORDJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 April 2024 at 5:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2024 at 9:41pm
End result with build in plate amps (i know what they resemble Wink).
Each sub can be used for multiple setups including 2.1.
Happy with the result, go low, but still sound tight.
Currently busy with a side project to build some amp modules around my own dimensions. A lot of the current (cheaper) options have basic plates that in most cases are quite wide. But that project will take quite some time and research to get some parts at a good price and will be a whole other topic when its time.
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2024 at 1:20pm
Slightly bigger cabinet will gain 2db at 40Hz. But if compact was the idea, then all good.
Yup, we are all just Hofmann's bitches in the end, like it or not.
fudge22 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fudge22 Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2024 at 12:23pm
Quote That is very inefficient.
There is a nice spike in efficiency at 50Hz.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2024 at 1:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2024 at 10:48pm
Won't get more efficient for a BR. Maybe lower mms driver or lower re driver to get numbers up, but a 18XL2000 in this volume is quite it. No magic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2024 at 8:19pm
