  New Posts New Posts RSS Feed - Moving on from DB Fortyline - HK Linear?
Andylaser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andylaser Quote  Post ReplyReply Direct Link To This Post Topic: Moving on from DB Fortyline - HK Linear?
    Posted: 08 November 2023 at 9:20pm
RCF have just released the new SUB8003 Mk3. A pair of these each side with an NX32A on top would be pretty good. If you can stretch budget to the 8004 subs, even better.
"music so loud, that if we move in next door to you; your lawn will die" - Lemmy
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 07 November 2023 at 5:01am
I haven't heard anything HK Audio stuff used in anger over a longer periode of time. Only a short demo of a Contour Array setup. 3 subs and 3 mid-hi each side.
That sounded pretty good and loud. I guess a stack would match a stack of Forty line Smile
A stack consisting of one sub and one mid-hi.
Edit: forgot all about HK Audio Projector system.
That would be a great piece of kit for you also. But that might be hard to find these days.
Not the biggest low-end performer system, but its a good sounding system.
Edited by FOO - 07 November 2023 at 5:10am
mattd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattd Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2023 at 5:05pm
Thanks RCF is on the list :) open to suggestions of what to look for.
Certainly would he happy with an RCF system. I also see DB tech (esp Fortyline) as cheap RCF but with poorly made boxes!
Interesting no one has backed the HK actually! I'll keep researching :)
Edited by mattd - 06 November 2023 at 5:08pm
Wikl109 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wikl109 Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2023 at 12:02pm
Matt, have you not considered an RCF system yourself?
They have a big range of active cabs and there seems to often be second hand systems coming up.
I was always under the impression that DB Technologies was always basically marketed as RCF's budget brand.
Decent enough but cabs that were often made in India or China rather than Italy (So more built down to a cost).
I know a couple of people who have DB Tech gear and seem very happy with it but it's always seemed a bit 'Cheesey' to me.
The type of kit your likely to see being used around a pool at a holiday resort.
If you do like the sound of what you have then surely RCF should at least be on your shortlist.
Cheers, Chris.
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2023 at 10:02am
I have been the happy owner of DB tech before. But shifted to RCF. Easyer to rent more boxes around here, if more is needed.
Anyways... I used the DVX D12 amongst others. Insane little thing! Not at all entry level. But I know what you are trying to say. The name isn't up there with the big boys Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattd Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2023 at 6:20am
Not usually, but I definitely get people asking what the kit is. I dont feel it has lost me work ever, but I think better known brands might gain me more in future.. DB Tech feels entry level , although saying that the Fortyline sounds pretty good IMO.
fudge22 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fudge22 Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2023 at 9:27pm
Quote D&B is very hireable
Going off at a bit of a tangent, but is it common that you get bookings based solely on the brand of gear that you use?
All my work comes either from people who I have worked with recommending me to others, or people at gigs asking for a business card. Not once has anyone questioned, let alone been put off by the gear that I use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattd Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2023 at 5:10pm
Thanks for this.
I have plenty of powerlight amps and some FFA's so maybe that is a option. I'll do some research.
Edit: taking into account lack of rave appeal mentioned above maybe the C7 / Dynacord isnt my best bet. That is most of my work.
Edited by mattd - 05 November 2023 at 6:41pm
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2023 at 3:26pm
If you are going down that road with cube boxes, then D&B C7 is a great system no doubt about that, and will fit your needs good.
But there is also Dynacord XA2, Cobra 2 or even better, Cobra 4.
XA2 would be a step down from D&B C7 but cheaper. Cobra 2 would be equal. And Cobra 4 would be a step up from C7/equal to D&B C4 but with a bit better LF respons.
Biggest advantage with Dynacord would be that you don't need to use specific amps. It's totally up to you 🙂
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2023 at 1:27pm
We use C7 for loads of stuff, Its a bit older but a fantastic system for good consistent sound.
The C7 tops are square, the subs are rectangle but the same width so it stacks nice.
D&B is very hirable, I have a fair pile of it now and it's all paid for itself time and time again. But it isn't really free party / rave hirable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattd Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2023 at 11:39am
Thanks Jace.
That is not a bad idea really in general, the name would speak for itself. I have considered that before, my main system is Ohm I love the 218s but less so the tops and neither are compact. I actually use NCA A2D2 top boxes on top of Ohm 218s as my preferred combo but obviously that is less hirable.
Six boxes of D&B would properly get me more work, they are fairly compact cube boxes if I remember right?
80% of the work is the smaller active system for under 150  / 20% rave systems for 500 odd with either 4 or 6 218s. Maybe the D&B would fill the gap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2023 at 9:10am
How about D&B C7?
It’s about £1000 a box and the P1200 amps can be had for about £600 each.
Get 2 tops 2 subs 2 amps then buy the extra pair of subs when you have a bit more £££
Will put you in a completely different bracket.
