  New Posts New Posts RSS Feed - eighteensound designs
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Topic: eighteensound designs
    Posted: 20 November 2023 at 12:06pm
Do you think Martin Audio were idiots when they put 18TBX100 in the last generation of the WSX? Or the D&B Audio at their B2? Or many many other professionals?
Also you will find feedback from many people, who built their own WSXs, and loaded them with Void V18-1000, reported superior performance, than original cabs with original drivers.
Response would not be as uniform 30-100hz, but 40-50hz would have substantial peak,due to V18-1000 30+ BL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2023 at 3:07pm
2420 is more modern variant than 18TBX100.
I remember the days when you said 18NLW9601 is not good for scoops :)
Think people who use FLH, are looking for different sound, to those who use Scoops.
Scoops dudes prioritize huge sensitivity @40hz, with sub warmth, FLH fans prefer clean, uniform response.
Reggae Scoop dudes, will use Pre-amp to shape sub, FLH dudes tend to stick with just Mixer and LMS.
I actually use LMS and bass pre, to shape Scoop sound.LOL
Also 18NLW9601, is a Rolls Royce sub driver, but really needs substantial power input, and right sub shaping to get "warm" sound.
Edited by levyte357- - 18 November 2023 at 3:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2023 at 2:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2023 at 1:49pm
Lev, why do you think 2420 is not good for scoops?
Obviously different people desire different response from their Scoops.
Think Rog actually said it initially , and my modelling confirmed it, and Mykey actually said it.
BL approx 25, will give you pretty flat response in Scoops, High BL >= 30, gives you the 40hz bang, flattened out by stack of 2x - 4x.
This is possible reason many used to say, in Scoops, Fane 18XB was more musical than 1850, more warm sounding, but not the killer 40hz bang.
Also the EBP of < 100, also suggests better in a reflex.
Edited by levyte357- - 18 November 2023 at 1:56pm
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2023 at 10:04pm
is there a suggested design online for that driver on the 18sound site? have a butchers
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2023 at 8:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2023 at 2:10pm
Originally posted by KlaasBlackPaw KlaasBlackPaw wrote:
Ah I see my fault, it meant to say 18LW2600, not the NLW4500***
OK, the 18LW2600 t/s parms, definitely suggest, it would be optimal in right Scoop.
This would be a great starting point, for a cab for this driver, but, needs mods, so driver will fit, with sufficient rear clearance.
Edited by levyte357- - 17 November 2023 at 9:26am
KlaasBlackPaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KlaasBlackPaw Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2023 at 1:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote KlaasBlackPaw Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2023 at 1:08pm
Ah Levyte, I was hoping to find a reply from you on here :)
The reason I suggested LW2420 or NLW4500 is because both are suitable for hornloaded applications, and have the xmax/freq range desired.
I'm a total newby when it comes to designing / reading T/S parameters so I just chose based on the parameters I knew / woofers I knew.
So even though the LW2420 are suitable for hornloaded applications, you'd suggest putting them in BR?
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2023 at 10:32am
Hello and Greetings everyone
I was wondering if anyone was in the know of Scoop plans for the eighteensound 18LW2420 (updated model of the 18LW2400) or eighteensound 18nlw4500 woofers?
I would suggest, 18LW2420, would be more optimal, in a reflex cab, and I actually have 4x in reflex cabs.
Any particular reason you are choosing 18nlw4500?
Be aware, it has cutout of 422mm and depth of 233mm.
Also be aware, it has a  no of 1.8, which means it really will require more power, for desired SPL, than many other drivers.
Edited by levyte357- - 16 November 2023 at 10:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote KlaasBlackPaw Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2023 at 12:40pm
I was wondering if anyone was in the know of Scoop plans for the eighteensound 18LW2420 (updated model of the 18LW2400) or eighteensound 18LW2600 woofers?
Edited by KlaasBlackPaw - 16 November 2023 at 1:19pm
