Uses for 6.5ohm LAB12 Drivers |
Requiem
Joined: 20 January 2011 Location: Bristol Status: Offline Points: 1808 |
Topic: Uses for 6.5ohm LAB12 DriversPosted: 18 December 2023 at 1:58am |
Hiya guys
Come into possession of a load of these from a job lot which i'm trying to sell and I just wanted to know more about how they can be used, I know they are the drivers designated for the LAB sub, but can they be used in anything else? How does it work with the 6.5ohm load and the dual loading in the lab horn, i vaguely remember reading something about it on here about the cab design changing the ohm load or something but Ive been searching the forum for ages and couldnt find the right thread Any links to correct thread or other uses would be great, thanks. |
www.requiem-soundsystem.com
Custom Martin Audio WSX, USB & CSG Soundsystem based in Bristol |
Lucasdude
Joined: 16 March 2013 Location: London Status: Offline Points: 986 |
Posted: 18 December 2023 at 11:05am |
The specs are unusual. Fairly high qts, very low sensitivity, only a 2.5" vc for a claimed 400w handling and also a fairly low BL. I would think with such a low resonance that they would probably work in a sealed box for HC, or in pair in a reflex box for a car. Although the 6ohm impedence isn't ideal for a car amp, a muscular one should push a parallel pair OK.
Xoc1
Joined: 15 October 2012 Location: Devon UK Status: Online Points: 485 |
Posted: 18 December 2023 at 1:08pm |
Lab 12's have been used Reflex & tapped horns as well as FLH
JonB67
Joined: 22 April 2016 Location: UK Status: Offline Points: 1352 |
Posted: 19 December 2023 at 11:22pm |
Keystone also does double 12" labs iirc.
Definitely worth a look. Think member doller on here also built some subs with labs of his own design. Google the archives!
sarsen1
Joined: 01 January 2016 Location: Bristol Status: Offline Points: 130 |
Posted: 20 December 2023 at 10:12am |
Loads of info on tapped horn designed for this driver here: $325 Lab 12 based PA tapped horn ~ 35Hz extension | diyAudio
