  New Posts New Posts RSS Feed - Problem minidsp/sure + powersoft digimod
Angelow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Angelow Quote  Post ReplyReply Direct Link To This Post Topic: Problem minidsp/sure + powersoft digimod
    Posted: 31 July 2024 at 5:28pm
Hi everyone, I have a mini dsp that I want to use to bi-amp some speakers. I have some powersoft digimod 1000 and 500 that can be used both unbalanced and balanced, but the output level of the Mini dsp with an RCA connector is too low in terms of volume to be able to drive the amplifier. I tried some adau modules from sure and the result is the same. Where can I buy a PCB that acts as a preamplifier between the DSP and the amplifier? AliExpress? How should I search? Do you have any links? Thanks
VECTORDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VECTORDJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2024 at 1:17pm
Buy a Real Crossover/DSP.....DBX Driverack is very Good for the Money.
KDW32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KDW32 Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2024 at 6:03pm
I think he's trying to make an active box
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 02 August 2024 at 3:03am
What you are looking for is a Distribution Amplifier. The Aphex 120 Distribution Amplifier will deliver close to 14 volts on it's balanced output.
Best Regards,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Angelow Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2024 at 9:41am
hi, i need it for an active speaker box
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2024 at 1:59am
So, you rather not feed the MiniDSP into a Distribution Amplifier to a powered box?
Your limiting factor is MiniDSP as it is a Home Audio grade Crossover Network. You are basically going from one extreme to another.
Best Regards,
fudge22 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fudge22 Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2024 at 10:17am
Quote So, you rather not feed the MiniDSP into a Distribution Amplifier to a powered box?
From the first post, it would appear that the miniDSP is being used as a crossover. A separate amplifier for each output is thus required. The distribution amplifier you mentioned is a 1 in 4 out. He would need 2 of them per cabinet. RDL do a number of more suitable unbalanced to balanced converters, but they are pricey.
There was no mention of where the completed system is to be used, so if it is to be used at home I guess home audio grade is fine. The only problem, irrespective of use, is the limited output level of the dsp, or looking at it the other way, the lack of gain in the digimod.
If Angelow can use a soldering iron, making a custom preamplifier board, with a few op-amps, resistors and capacitors, would not be too difficult. Do a web search for balanced line out circuits. Most audio equipment uses variations on the same circuit. It might also be worth checking to see if the gain of the analogue output stage of the dsp can be modified to give more output.
A search on AliExpress for “preamplifier boards” brings up plenty of results. Whether any are suitable I can’t say.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2024 at 10:38am
Distribution Amplifiers are offered in many configurations. The one I mentioned (own) is an example what you can expect in terms of output voltage. Angelow will need to research the right Distribution Amplifier for his requirements. As Angelow is using a Powersoft Module, he is going to have to invest in the proper tools to fill in the gap, if he wants to use miniDSP.
Best Regards,
Post Options Post Options   Thanks (0) Thanks(0)   Quote fudge22 Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2024 at 10:52am
Quote Distribution Amplifiers are offered in many configurations. The one I mentioned (own) is an example what you can expect in terms of output voltage. Angelow will need to research the right Distribution Amplifier for his requirements.
Thanks for clarifying that you agree the device you suggested is unsuitable for the OP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2024 at 10:57am
I prefer giving ideas so many can explore multiple options by a means of research.
Best Regards,
Robbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2024 at 11:51am
I know that this may sound a bit obvious but have you tried making up a single co-ax lead from the unbalanced RCA connector to a male XLR and wiring the XLR pins as pin 2 live and pin 1 linked together to pin3 thus unbalancing the XLR end of the lead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Angelow Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2024 at 11:14am
Hi, I've already tried to make the cable, but the problem is the voltage coming from the mini dsp! On AliExpress I can't find anything that is small and can be inserted into a small case.
More than balanced, you need an adapter from -10 to + 4 dbu
