Reflex Enclosure for 18Sound 21LW1400 |
PHATpedro
Topic: Reflex Enclosure for 18Sound 21LW1400Posted: 10 May 2025 at 6:26am |
Hi I am new here and I am searching the internet for a rexlex enclosure for the 18Sound 21LW1400 driver, as I am building my first rig.
I will buy two of those. I want to build two single driver enclosures This system will play mostly Dub, OG Dubstep, Jungle I would like to tune this enclosure to 30hz or lower if that makes sense, but i think 18sound recommends 30hz. Why so backwards? I live in Mexico and I have very limited driver availablity, basically this is the only 21" driver i can get here where I am. I do not need to play brutally loud but I need to play deep. We have reggae soundsystems here that play incredibly loud, but that is not what i want. Here is the driver https://www.eighteen.it/en/products/lf-driver/21-0/8/21LW1400 - https://www.eighteensound.it/en/products/lf-driver/21-0/8/21LW1400 Resonance Frequency 28hz Frequency Range 24-2000hz Xmax 9,5mm Recommended Volume 300L Hopefully you can help me. Kind regards |
FOO
Joined: 23 December 2018 Location: Denmark Status: Offline Points: 953 |
Posted: 10 May 2025 at 7:13am |
If you are up to it, i can recommend this design.
It's not super easy to build, but it do sound good. Heard them a couple of times, 2 subs each side with 2 EV RX212/75 on top each side. |
PHATpedro
Posted: 10 May 2025 at 7:45pm |
I thank you for your response.
Unfortunately it is not what I am looking for. I have discovered it on their webpage and it seems they used to have a single reflex 21" plan. I found several links iirc but theyre all dead. I would use it if it was still around. I ofc. also like the ease of built for a reflex cab. Thanks a lot. |
