  New Posts New Posts RSS Feed - Can two IlLDA leads be linked to gether?
PolymorphicMark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PolymorphicMark Quote  Post ReplyReply Direct Link To This Post Topic: Can two IlLDA leads be linked to gether?
    Posted: 16 June 2025 at 9:28am
I going to be using a Laser at an event for the first time. Yes I have studied the safety guidelines.
I have a 10m ILDA cable but it looks like I may need to extend it, can I just get a 5m ILDA cable and connect it to the 10m? One end is Male and the other is Female so I can't see why i can't join them.
Mark
Free to do what i WANT
James Tengo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Tengo Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2025 at 1:20pm
You can extend ILDA cables no problem, just be aware that not all parallel printer cables came fully wired
FlipC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FlipC Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2025 at 8:52am
I use rj45 adater/turn around
