  New Posts New Posts RSS Feed - Eminence Sigma Pro-18A v1 Spec Sheet
ethnbh0110 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ethnbh0110 Quote  Post ReplyReply Direct Link To This Post Topic: Eminence Sigma Pro-18A v1 Spec Sheet
    Posted: 11 September 2025 at 3:04pm
Hi all,
I have a pair of both the Eminence Sigma Pro 18-A v1s and v2s. I am struggling to find specs for the v1s anywhere online. Eminence only advertise the spec sheet for the v2 and there doesn't seem to be any record of the v1 which were released in the 90s and have a purple label on the back. Reaching out to see if anyone here has a spec sheet for them or has any leads on why there isn't any existing information about them. I am cautious about treating them as if there the same driver because they look physically different and the v2 will likely be an upgrade or a solution to an issue with the v1.
Cheers,
Ethan
APC321 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APC321 Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2025 at 4:49pm
Try emailing Eminence on info@eminence.com
I have found them very helpful for answers to this kind of question.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ethnbh0110 Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2025 at 4:58pm
Hi,
Thanks for your prompt reply. I have emailed eminence but they haven’t got back yet, only with an automated message saying to read their FAQs. Maybe I just need to be a bit more patient, haha!
Cheers
Ethan
Post Options Post Options   Thanks (0) Thanks(0)   Quote APC321 Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2025 at 5:46pm
I hope that Eminence give you an answer to your question, rather than being yet another audio company to reduce it's customer service.
Fingers crossed...
Post Options Post Options   Thanks (0) Thanks(0)   Quote ethnbh0110 Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2025 at 6:07pm
Appreciate the advice, and I hope so too!
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2025 at 6:10pm
from archive.org, 2002
Nominal Basket Diameter
18", 457.2mm
Impedance
8 ohm
Power Rating      500W rms
Resonance      28Hz
Usable Frequency Range      25Hz - 2.5kHz
Average Sensitivity 1W @ 1m      100 dB
Magnet Weight      95oz.
Gap Height      0.375", 9.52mm
Voice Coil Diameter      3", 76.2mm
Mounting Information Overall Diameter      18", 457.2mm
Baffle Hole Diameter      16.56", 420.5mm
Front Sealing Gasket      fitted as standard
Rear Sealing Gasket      fitted as standard
Mounting Holes Diameter      0.25", 6.4mm
Mounting Hole B.C.D.      17.25", 438.2mm
Depth      8.15", 207mm
Shipping Weight      27.2 lbs, 12.4 kg
Thiele-Small Parameters Resonant Frequency      28Hz
Impedance (RE)      6.29 ohm
Coil Inductance (Le)      1.90mH
Electromagnetic Q (Qes)      0.30
Mechanical Q (Qms)      8.28
Total Q (Qts)      0.29
Compliance Equivalent Volume (Vas)
     441.2 liters
15.58 cu. ft.
Peak Diaphragm Displacement
Volume (Vd)      688cc
Mechanical Compliance
of suspension (Cms)      0.24mm/N
BL Product (BL)      22.1 T-M
Diaphragm Mass inc. Airload (Mms)      130 grams
Equiv. Resistance of mechanical suspension loss (Rms)      2.81N*sec/M
Efficiency Bandwidth Product (EBP)      95
Voice Coil Overhang (Xmax)      6.0mm
Surface Area of Cone (Sd)      1140.1cm2
Impedance at Resonance (Zmax)      180 ohm
Materials of Construction
    Kapton coil former
    Ferrite magnet
    Die-cast aluminum basket
    Polyamide-imide coated copper voice coil
    Paper cone/cloth cone edge
    Solid composition paper dust cap
Post Options Post Options   Thanks (0) Thanks(0)   Quote ethnbh0110 Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2025 at 6:58pm
You’re an absolute legend. Do you think you could send me the link to the archive page where you found them please?
Cheers
Ethan
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2025 at 8:04pm
Archive.org
Post Options Post Options   Thanks (0) Thanks(0)   Quote ethnbh0110 Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2025 at 8:53pm
I meant the url for the specific page but that’s fine. I will search it up myself.
Cheers
Ethan
Lucasdude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lucasdude Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2025 at 12:16pm
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2025 at 3:33pm
Note that apart from the reduced power handling, (500W vs 650W), those are the current specs per Eminence's website: https://eminence.com/products/sigma_pro_18a?_pos=1&_sid=588aaf204&_ss=r#specifications
Now it might just be that the difference in power handling was the only difference between the older and current ones, but hopefully the OP will get the full info from Eminence in due course.
Edited by DMorison - 13 September 2025 at 3:45pm
