  New Posts New Posts RSS Feed - 2-way soundsystem?
2-way soundsystem?
Dead_quiet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dead_quiet Quote  Post ReplyReply Direct Link To This Post Topic: 2-way soundsystem?
    Posted: 13 November 2025 at 8:27pm
Hello everyone, I'm here to present my project and try to get some answers. I've built four 15" subwoofers (SATH 115 - 99dB 1W 1M, 1000W AES, 41 to 110hz).
Originally I was thinking of making a 3-way system, but now I want to imagine a 2-way system.
The project is to have a sound system that allows us to play a fairly wide range of styles (electro, dubstep, house, techno, disco, funk and more), primarily for DJ sets.
The goal is to achieve a beautiful, natural, detailed, clear, rich, and full sound with good bass extension and a bit of impact.
We're not looking to provide sound for huge spaces or large venues, so the trade-off will likely be the output.
With versatility in mind and to simplify setup, we are considering a 2-way system.
The advantage of our 15" subs is that they perform very well up to 110 Hz.
The idea goes somewhat against the grain of traditional sound systems that are stacked in 3, 4, or 5-way configurations.
The idea is to use stacks of 3 subs with one tops per stack. The goal is to be able to deploy them depending on the size of the event, with one, two, or 3 stacks.
For these 3 subs, I plan to use a high-performance 3-way.
The absence of a kick bin would deprive me of a powerful impact, but instead I am ready to prioritize a balanced but fairly nervous sound in these frequencies.
What do you think of my reasoning?
Do you believe a minimum of 3-way is necessary, or is 2-way a viable option based on my project?
thank you
Meat Substitute View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Meat Substitute Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2025 at 8:54pm
The rig I had out last weekend was 18-15-2 and had nothing but compliments. The cabs are all reflex. The tops can play down to 45Hz and the subs up to 300Hz if I need to.
I've had just the 15+2 tops out before on their own and they were good for family parties and PA type work but for DJ stuff having the subs too is miles better.
I used to have kicks and a more complicated rig but the simple setup now sounds better and is less of a pain in the ass.
I'd like to see a 2 way rig using an 18+2 with some of the crazy new drivers out there though...
Conanski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 14 November 2025 at 1:18am
Your complete system is going to be 3-way.. subs, mids, highs, there is no way to build a PA system with fewer than 3 bands and achieve true fullrange sound.
That means 2-way tops which could include a passive crossover but it will perform better when all active.
"The advantage of our 15" subs is that they perform very well up to 110 Hz. "
OK but that still isn't high enough to meet even a large 2" exit compression driver which will have poor response above 8-10khz. There are now coaxial compression drivers like the B&C dcx464 that might be usable from 500hz up(its rated for 300hz but IDK what that sounds like), but that still leaves a sizeable low-mid gap.
Edited by Conanski - 14 November 2025 at 1:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 14 November 2025 at 1:43am
No. I grew up hearing rigs that consisted of things like a 15" scoop with a big horn on top, it got loud but it was all mids with no lows or highs... not good. I know DSP processing would vastly improve that now but it's still not possible to get deep powerful lows and clear mids from the same driver.. it's a physics problem, an 18 would make the problem worse.
Edited by Conanski - 14 November 2025 at 1:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dead_quiet Quote  Post ReplyReply Direct Link To This Post Posted: 14 November 2025 at 9:25am
thanks
When i speak about 2-way, i mean 2 cabinets, subs + large band speaker like most of traditional PA systems.
If i go up to 110hz with my subs, you don't think that a 3way speaker with dual 12" or 15"+8"+ compression on top of that couldn't manage to produce clear and balanced sound?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Meat Substitute Quote  Post ReplyReply Direct Link To This Post Posted: 14 November 2025 at 9:37am
I think what you're suggesting is totally fine. 2 way bass is normally not needed for most things.
We have another system that goes straight from 18" to 2x8"+1" and that sounds fantastic. Crossed over at 180Hz.
Obviously this will depend on the exact details of your cabs but crossing at 110Hz should be totally ok. Just get everything aligned properly and you're away.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dead_quiet Quote  Post ReplyReply Direct Link To This Post Posted: 14 November 2025 at 10:29am
thank you, IMO it should be working.
Knowing that I'm a beginner in this field and don't have much experience, I get the impression that the kick is becoming a kind of standard in DIY PA and that it's not necessarily essential. Tell me if I'm wrong, but if you want to play dub or techno, then this element seems indispensable; moreover, the audience is looking for that feel.
On the other hand, if you don't use a kick , is it possible to imagine a rich and energetic reproduction in the 100-200Hz range? The impact in the chest might not always be the most pleasant thing after all? perhaps just a nice feeling about this range could let more space to the whole sound?
I'm trying to look at things differently.
Edited by Dead_quiet - 14 November 2025 at 10:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2025 at 1:09am
Oh it most certainly would you just have to realize that what you suggest is a 3 or 4 way system... it doesn't matter if the drivers are all in one cabinet or in separate boxes.
madboffin View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2025 at 4:09pm
Just to add to what others have said, what you're building would normally be described as a "two-box" system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dead_quiet Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2025 at 8:05pm
Hello, yes, I was referring to a "two-box" system.
After thinking about it, it seems complicated to design this kind of system without using very large tops.
My subs are compact, so it seems logical to do the same for the rest of the system.
A 12" kick reinforcement with two 8" or 10" tops seems like a better option.
Smaller boxes would be easier to store and move (I live in the city and don't have extensive logistical resources...).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2025 at 8:55pm
Single 12" 2-way boxes will still be smaller and easier to move than 15" subs, there is something to be said for system simplicity too... less external wiring. There are 2 ways to build a box like this depending on what you want from it, use a 1" exit CD with a 2khz internal crossover and a mid-bass 12, or use a 1.4" CD to crossover to a more bass oriented 12 at around 1.2khz. The first option gets a bit louder and has good topend extension but may be a little light in the kick region, the second option produces stronger kick and mids(vocal range) but needs some EQ help on the very topend.
Steve20131 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve20131 Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2025 at 10:29pm
Yes you are right,  if handleability and space are a problem,  8" tops would be better.  B&C and LaVoce make affordable 8" that will port easily down to the frequencies you specify and punch well into the 120's.  Thats just two,  if your 15's are super duper you will need 4.  Wiring for 16ohm will still give you enough spl but your amplifier will run cooler, TID will reduce and slew rate improve.
Again if sound quality is important using 20 10w 2" dome tweeters will make crossing over easier really flexible, remove standing waves and the squashing noise cd's make. Comb filter will only be a problem within 5 feet which proximity your ears will be more deformed than the sound
hold on......say this
These are so dirt cheap!!!!!
