  New Posts New Posts RSS Feed - X32 as LMS
X32 as LMS
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Topic: X32 as LMS
    Posted: 17 March 2026 at 11:08am
Hi, am working with some friends developing their ambisonic system.
There's a real need for proper processing. It's a 12-16 way system depending on the deployment.
At this time, the only cost efficient solution for LMS (as well as general IO duties) appears to be a X32 rack, or similar.
Will probably get the DANTE card too to link to the ambisonic software.
My question is, how does it handle some basic LMS duties such as crossovers, delay, and speaker protection limiting?
Anything else to be aware of?
Of course a soundweb or xicilia would be preferable, but at this price, with DANTE card, the X32 is an easy buy.
I'd also ask if anyone has experience with the DANTE card. Can the DANTE outputs from a PC be hardwired to the mixer outputs, without using input channels?
Xoc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xoc1 Quote  Post ReplyReply Direct Link To This Post Posted: 17 March 2026 at 1:17pm
You can link Dante I/O thru the PC with Dante Via software. It has a fixed delay which I think is 10mS - but it lets you route audio in and out of the PC thru the LAN. No harm in trying - as its fairly cheap & has a 30 day free trial.
