12"+8"+1" Mid/High Plan |
Maffy Dmg ![]() New Member ![]() Joined: 08 January 2022 Location: Brindisi Status: Offline Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 19 January 2022 at 3:36pm |
What a bundle, thank you
djeddie ![]() Old Croc ![]() ![]() Joined: 26 April 2004 Location: Bristol Status: Offline Points: 4107 |
Maybe out of luck there Alex, the last time the OP was on this site was 13 years ago!
Good evening
my name is Alex, I would like more technical specifications on this project because I would be interested in building it thanks.
ArthurG ![]() Young Croc ![]() ![]() Joined: 03 May 2004 Location: France - China Status: Offline Points: 976 |
first tb_mike is right and 2nd I don't want to be too rude but this Eminence 8" sounds like crap above 2k... the extension of response frequency is because of mechanical resonance. in other words, it produces more distortion than anything else... that's why it's so cheap...
tb_mike ![]() Old Croc ![]() Joined: 01 October 2004 Location: New Zealand Status: Offline Points: 2744 |
You realise that those sensitivity measurements were made on a standard enclosure or baffle, so on a horn it doesnt count. Also youl notice that the 6" will have almost half the cone area of the 8"- thus giving the +3dB. Remember that the highest frequencies are effected by teh first part of the horn. So from what I can see from your diagram,the dispersion will be more narrower in the upper region of the midhorn,where it will cross over to the HF horn. |
Jake_Fielder ![]() Old Croc ![]() Joined: 08 October 2007 Status: Offline Points: 4231 |
Well it seems like a good idea, im especially interested as im goin to be building some midtops soon. as pooju says: keep us updated
Cheers
bmf2 ![]() Registered User ![]() ![]() Joined: 04 November 2007 Location: United States Status: Offline Points: 68 |
I picked the 8" because of the 101 spl. The Eminence LA6-CBMR 6-1/2" I was thinking of using is only 97. I would need two of them to keep up and they aren't available in a 4 ohm which would cause me problems in wiring the cab up (two 4 ohm series for 8 ohm). The 8" flare is designed to have two patterns. The first being a wide pattern and when the inserts are installed being a 40 degree. Both where compromised a little to make it work. Yes Jake this is a variation of the old design. I found a source for the High flare I wanted to use and got exact dims. for it so I could get a little further in the box design.
You say it's too loud-I say your hearing is too good
pooju ![]() Registered User ![]() Joined: 04 April 2006 Status: Offline Points: 254 |
How have you designed the 8 flare on the Bmf2 is it a scaled mt? have you gone for the 45x45 flare - if thats what it is - to match the first section of the the 8? -keep us updated!
unlucky on the rattling xover! |
Im really interested in how this design goes, I thought it was more conventional to go for a 6" driver with a 12" and 1", any reason for going with an 8"?? Im getting dejavu, Have you started a thread with tis design in already, and tony told you to line up the drivers.....? or am i completely insane?!
EDIT: Haha here it is (BAM!) how come you dropped this design? Edited by Jake_Fielder - 16 January 2008 at 9:27am |
Just a sidenote:
While playing last Sat. I lost one of my mid/highs 3 songs into a set. The band took a break as soon as possible and I started backtracing. I ended up all the way back to the cabinet itself. I pulled the jack plate off to find the very complicated crossover/zobel had vibrated loose and ripped the wires off of everything as it fell to the bottom of the cabinet. Sweat is building because we had just took our other cabinets out of the trailer a couple days earlier. I went to emergency repair method one. Solder the 15" back to one input jack and the top horn back to the other. Plugged in the mid line and high line and cringed the rest of the night.
![]() But I did manage to get the band back up in ten minutes.
Mark James ![]() Old Croc ![]() ![]() Joined: 15 January 2006 Location: rig side Status: Offline Points: 5293 |
mt121 isnt that easy but hey, how low can you get the 8" down to and still play up to 3khz???
might like to see the 8" plans lol..... |
me so horny me love you long throw
horn loaded for her pleasure |
If the mt122 design is good down to 120hz I'll stick with this design as it will be simple to build.
