  New Posts New Posts RSS Feed - cost to build a porn horn
robotnation View Drop Down
Member Banned!
Post Options Post Options   Thanks (0) Thanks(0)   Quote robotnation Quote  Post ReplyReply Direct Link To This Post Topic: cost to build a porn horn
    Posted: 09 April 2008 at 12:19am
hello all - i was wondering what the price would be to build my own porn horns?  I cant find a cheap source in america.  I would like to build two to use with about 4-6 hd15s.  I will build 6 hds if i can find one amp to power them all, and 4 hds if the porn horn cant keep up with 6.  Thanks for the help.
justamadman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote justamadman Quote  Post ReplyReply Direct Link To This Post Posted: 09 April 2008 at 1:35am
expensive basically, the build isnt to costly but the driver/ horn combo is. not sure if th eparts are available on your side of the pond
in front of the bass bins baby
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2008 at 10:48pm
porns would happily keep up with 6 lol, in fact a pair may even keep up with 8 to be honest depends what stuff you arre playing realy
insert silly sentence here
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2008 at 11:04pm
one porn horn could easily keep up with 6 hd15s... but if you in the states i would look at other cabs, standard mt121 would do you with a good horn 12" driver
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2008 at 11:09pm
surely 1 porn horn would not have the coverage / dispersion to allow just one per side - good to have at least 80 degrees im most venues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2008 at 11:17pm
you would think that Chris but the coverage is quite good... look at the quoted polar plots
if you only need two then they make sense... any more then two cabs and it starts getting expensive and other options become more appealing
Autograff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Autograff Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2008 at 11:40pm
sorry to ask but who sells porn horns and what kind of price are you looking at for pairs/4's?
adambomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adambomb Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2008 at 7:51am
www.proaudioparts.co.uk
They are amazing / quality / loud cabs... fully built they are around £1000.. thats the option I would go for if I was going for porns.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Autograff Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2008 at 3:32pm
£1000 for a single cab tho Ouch
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2008 at 6:18pm
look at the price of the compression driver alone though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Autograff Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2008 at 3:15pm
i know , ouch , worth it the look of things if you can afford it tho.
Edited by Autograff - 29 November 2008 at 3:16pm
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2008 at 8:45pm
The price of a fully built cab versus components is so small that you'd be a bit silly to think about building unless you you REALLY enjoy the building.  By the time you factor in additional parts, paint, grille, etc its looking a very close run thing on price, not to mention time.
