  New Posts New Posts RSS Feed - Which Re-Cone Glue
Which Re-Cone Glue
CHAMPION View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Topic: Which Re-Cone Glue
    Posted: 19 September 2008 at 8:37am
Chicken, you try and remove it if the coil blows !!! Nightmare, Labour ££ goes up
Sticks n Stones
chickenfizz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickenfizz Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2008 at 4:40pm
Araldite is what I've used for spiders and the edge of surrounds, this might not be THE RIGHT way of doing it but it's always worked for me :) I use bog standard pva for dust caps. The only time I've used different glues is when the kit actually comes with them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2008 at 4:21pm
A few PD Voice coils we reworked after Carnival  5" Dia 2.5cm coil width Well Done !
Section removed to see what chemical can remove the super adhesive
Hey Presto, it has worked without damaging any material
One of the most Labour intensified chassis to work on, as the adhesive is ment for a a permanent bond! (instead of a nut&bolt use a weld) !!
This is what PD Use for Dust caps, a activator and a  cyanoacrylate adhesive
The next best thing would be to use a clear basic paper adhesive Evo-Stick 5007/2
The same  (activator and a  cyanoacrylate adhesive ) is used for Spider to voicel coil joining,
Edited by CHAMPION - 16 September 2008 at 4:28pm
Sticks n Stones
Centauri View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Centauri Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2008 at 4:05pm
For spiders / surrounds / dust caps I use Bostik MultiBond , but I can't see that on the Bostik UK website - may be similar to their Evostik Serious Glue but not sure.  I wouldn't use a contact adhesive for this.
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2008 at 3:13pm
Myself and many other people use an impact adhesive by Evostick or Bison for gluing the spider and surround to the chassis.  Just make sure you get it in place first time!!!
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2008 at 10:33am
Wembley LS use Tretobond
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2008 at 10:06am
lol Coke cola
Try getting some of this stuff, im trying to source it ....
best stuff, looks like only made in USA !
Sticks n Stones
Pinheiro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pinheiro Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2008 at 8:34am
hi
i done recone on more then 200 recones  from DAS, PD(turbosound),JBL,RCF and more  and the glue is always this
http://www.bartolos.pt/store/files/cola_de_contacto%5B1%5D.jpg
hope it helps yours Vitor Pinheiro
ashdosseposse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ashdosseposse Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2008 at 11:11pm
new cones with the coil fitted... i want glue for the surround
If i had eyes and teeth i'd be a whole head! [Memoirs of an Invisible Man]
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2008 at 10:15pm
What kit was it though? If the coil is already attached to the cone then you don't need that glue. Your answers are here
I use an ACTIVATED super glue for the dust caps.
Nick
Post Options Post Options   Thanks (0) Thanks(0)   Quote ashdosseposse Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2008 at 11:43am
Well i had one type of glue for bonding off beyma which looked like evostik plus some pva for the surround
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2008 at 8:20am
http://www.loctiteproducts.com/
Use different types of adeshives on dofferent parts on the re-cone procedure. If your not sure speak to one of the manufactures, Fane,B&C, etc for advice.
Sticks n Stones
