X1 Delay |
matttcattt ![]() Registered User ![]() Joined: 21 April 2004 Location: United Kingdom Status: Offline Points: 106 |
![]() ![]() ![]() ![]() ![]() Posted: 08 August 2005 at 6:07am |
Thanks, I must have missed the autoalign feature when reading the Ultradrive manual...
Edited by matttcattt |
If it aint broke, don't fix it.
(and my own bit) If it is broke, fix it. (and more) If you can't fix it, take it apart and see how it "worked". |
norty303 ![]() Old Croc ![]() ![]() Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8806 |
Ultradrive, DR260 (iirc), probably some other but i'm not sure
Could you list a few LMS's that have an autoalignment feature? |
Yeah, delay on BP cabs is a luxury rather than a necessity. It just means that you hear the punch of the kick 15 or so milliseconds before the boom
Tumble ![]() Registered User ![]() Joined: 09 July 2004 Location: SouthWest UK Status: Offline Points: 353 |
can you use a measurement mic with a digi drive?
Retox
LunchieTey ![]() Young Croc ![]() ![]() Joined: 06 February 2005 Location: Australia Status: Offline Points: 934 |
If you use x1's without delay,you're still going to get heaps of bass
anyway,I think you might be considering speakers on 15ms of LF
delay(not a huge deal) instead of th 30hz extension and 130db output!
Just build em and worry about delays when you can afford an ultradrive or something! I don't delay my 6th order cabs(similar to x1) and they still rattle roof irons with the best of them! |
Speaker addict
soundgodwannabe ![]() Registered User ![]() ![]() Joined: 22 January 2005 Location: United States Status: Offline Points: 89 |
Okay, here is my two choices. I can either build two X1's or build one G2 subwoofers. I am wondering which would be best to use if I am using a 2/3 way crossover. They only thing that is stopping me in building the X1 is the mention of delays. I have not used them before and really am unaware as how to use a delay and why one is used. I just want something that will give me some bottom end, must be portable, and can be used indoors as well as outdoors. The G2 looks like a good way to go since I don't necessarily have to have a delay and it can be used outdoors. But at close to 150lbs, it doesn't look very appealing. A hand truck and castors are a must. Can someone shed some light on the subject of delays with these two subs? |
Make the soundman mad and I WILL press the suck button for your band.
Soll ![]() Registered User ![]() Joined: 27 February 2005 Location: Ireland Status: Offline Points: 9 |
Thanks will do as tb_mike says. Hmm Now the only problem is that The people doing the party want me to set up anouther system next to mine, 2x 1850 2x Martin w-bins mark 2, 2x Martin Philshave Midhorns, What a pain, plus they don't have the relavant exuipment to cross it over and delay it propaly. Don't really want to tell them no, I think they are going for a teknavill look.
If i stack them a bit away from my stuff...? |
Techno Slave
Timber_MG ![]() Registered User ![]() ![]() Joined: 27 March 2004 Location: South Africa Status: Offline Points: 1454 |
Group delay, if you use a controler it is easy enough to sort out (especially when you have some measurement system)
Hobbyist2004 ![]() Registered User ![]() Joined: 06 July 2004 Status: Offline Points: 99 |
Correct me if I'm wrong, but I think I remember Rog saying there were
no delay issues with the X1 as it is not a horn. May have been in the
old forum though.
Anyone else remember? |
ricky ![]() Registered User ![]() Joined: 25 October 2004 Status: Offline Points: 54 |
if you do what tb_mike says your system will play much louder. it is better to stop the low bass getting to your 15", thats why you use the x1.
