HD Copy |
ultramars10 ![]() Registered User ![]() ![]() Joined: 29 September 2012 Location: amsterdam Status: Offline Points: 25 |
![]() ![]() ![]() ![]() ![]() Posted: 17 May 2016 at 3:15am |
Hello, i'm precisely interested in reproducing the 80hz-250hz range, since i have C-subs below 80hz and R2Sh above 250hz: ommiting the piece of wood which gives separated the throat volume from the start of the horn is maybe a bit radical, but would it be an idea to reduce its depth by half in order to do such frequency range ? Edited by ultramars10 - 17 May 2016 at 3:18am |
tomschute ![]() Old Croc ![]() Joined: 15 May 2006 Location: Mid Wales Status: Offline Points: 1817 |
seems an odd product to rip off/push as it really isn't suited to the cheapo DJ setup. What are you gonna achieve with a couple of these - certainly not earth rumbling bass
![]() "these cabinets provide an ideal, all in one, flexible solution to your audio requirements." Well so long as you have another 3 ways to go with it! |
Out to lunch... stableaudio@hotmail.co.uk
www.stableaudio.co.uk Speaker Building Services |
chris_k ![]() Young Croc ![]() Joined: 14 April 2005 Location: United Kingdom Status: Offline Points: 1256 |
Yes.........They do sell some sh*te. They are fine for odd bits and bobs in an emergency (they are only round the corner from me).
These are probably a step up from the piezo / skytronic / generic crap they sell.
boycey ![]() Old Croc ![]() ![]() Joined: 25 June 2006 Location: Manor House Status: Offline Points: 1612 |
has no one noticed exactly who the seller is?
the only thing more dangerous than a person who doesn't give a f**k is a person who gives a sh*t.
Dont think they are Celestion. I was shown a couple of `their` drivers. 15" + 18". Looked very much like unbranded chinese. Cast chassis if i remember correctly |
adambomb ![]() Old Croc ![]() Joined: 10 April 2006 Location: United Kingdom Status: Offline Points: 3215 |
looking at the other cabs in the "range" it looks like they use Celestion drivers.
Well these cabs have seen the light of day.
Price has gone up £200 since i saw them. Hope the build quality has gone up. Flimsey curved section, Wood screws securing access panel!
![]() Edited by chris_k - 09 April 2009 at 8:37am |
Deadbeat ![]() Old Croc ![]() Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
By removing the front chamber he's made it into a single fold offset driver horn. You can model this on hornresp if you wish, there's a tool for it.
Away on extended leave.
levyte357 ![]() The 10,000 Points Club ![]() Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Looks definetly like it will go louder, throw further, with reduced sub. Taken away BP and made a full FLH he has. Increase rear chamber to lower response. |
does it not turn a band pass into a horn - a very short horn at that?
ceharden ![]() The 10,000 Points Club ![]() ![]() Joined: 05 June 2005 Location: Southampton Status: Offline Points: 11682 |
I theory it won't go as low but it should also perform better higher up. Might make it more of an 80Hz upwards kick bin rather than a 60Hz and up cab.
davey t ![]() Young Croc ![]() ![]() Joined: 11 March 2004 Location: Bristol UK Status: Offline Points: 1428 |
the curved reflector makes no difference. ommiting the piece of wood which gives seperated the throat volume from the start of the horn DOES and WILL make a big difference. i'm guessing it wont go as as low or sound as good
Minirig portable soundsystem movement
