DMX controller recommendations. |
Page 123> |
Dayveboy ![]() Registered User ![]() ![]() Joined: 05 February 2009 Location: Fife, scotland Status: Offline Points: 47 |
![]() ![]() ![]() ![]() ![]() Posted: 05 February 2009 at 3:39pm |
http://www.velleman.be/ot/en/product/view/?id=353412
thats a 512 usb kit, that i have built and used probably 20 times. works great for small set-ups. set up a laptop with it and the possibilities are endless.. well 512 channels endless :P
Its all Gravy
mk2_ginger_biscuit69 ![]() Old Croc ![]() Joined: 03 November 2008 Location: Brighton Status: Offline Points: 7801 |
H... ![]() Young Croc ![]() ![]() Joined: 21 July 2008 Location: UK Status: Offline Points: 1164 |
Mmm looked at this but the LED pars i have and need a controller for are on different dmx chans.
Prolight
1: Red
2: Green
3: Blue
4: dimmer / strobe
The units i have
1: dimmer / strobe
2: Red
3: Green
4: Blue
imageoven ![]() Old Croc ![]() Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2163 |
Markie, if you haven't chosen already, have a look at the 'LED remote comander' which is a prolight product. I've not used it myself but it looks suited to your application. Straight forward enough and you can add a foot controller, will only work with cans from the same manufacturer (or with same DMX layout).
i have the aurora2 interface, which has protection built in and responds very well running roughly 250 channels worth of movers scans strobes smoke and led pars, only slight lag when everything is on the go (ie: less than 1/4second), but ever so slightly noticable when you are on the controls.
norty303 ![]() Old Croc ![]() ![]() Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8806 |
http://en.wikipedia.org/wiki/RDM_(lighting)
More fixtures are starting to appear that support it but they are generally at the high end of things.
4D ![]() Old Croc ![]() Joined: 13 November 2008 Location: Winchester Status: Offline Points: 4178 |
thanks if its good enough for you.. then....................its good enough for me..
whats RDM |
[statingtheobvious]I'd reccommend those with isolated I/O and avoid those without[/statingtheobvious]
![]() But seriously, I think a lot of this is going to be dictated by what software you want to run. Some software requires their own dongle to be used, others support a variety of the independant options out there.
I can only talk from experience of the Enttec Pro interface. I chose this because it is one of the more widely supported ones, whilst doing its own processing (rather than the PC) and has properly isolated ports
There are other options out there but at the time I bought it none really had the support of the Enttec. As I wanted to use Chamsys it was the obvious choice.
So any recommendations of which units to avoid and which to use.
I suspect thats to do with the design of some interfaces not using isolated DMX I/O.
This means that any power that finds its way onto a DMX line can get passed back to the laptop/lighting desk with obvious results. Something to check when buying an interface as few quid more at the start could save you a lot of quids later on.
What is this about usb/dmx interfaces and fried laptops
djgorey ![]() Young Croc ![]() ![]() Joined: 29 December 2007 Location: S. Wales Status: Offline Points: 1306 |
Cheers! I can see a spend coming on (but only a small one, thanks to software price!!)
I've always fancied getting the lighting sorted and with a nice computer based system like this (not expensive at all really - even the Enntec one is roughly the same price as Maplins), it allows me to play around with it at home.
I thought I'd stopped spending money on lighting! Edited by djgorey - 16 January 2009 at 9:10am |
Page 123> |
