  New Posts New Posts RSS Feed - Letterbox X1 plan
Letterbox X1 plan
AM55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AM55 Quote  Post ReplyReply Direct Link To This Post Topic: Letterbox X1 plan
    Posted: 04 January 2009 at 9:23pm
Have tried a search but cant find it anywhere. Can someone point me in the right direction.
Cheers  Thumbs Up
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 04 January 2009 at 9:25pm
Funnily enough, in a thread with the same title as yours!
AM55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AM55 Quote  Post ReplyReply Direct Link To This Post Posted: 05 January 2009 at 9:46pm
Thank you, i must be blind.
abrupt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abrupt Quote  Post ReplyReply Direct Link To This Post Posted: 05 January 2009 at 11:16pm
what is the better of the 2
gwarntek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gwarntek Quote  Post ReplyReply Direct Link To This Post Posted: 05 January 2009 at 11:51pm
If you mean the letterbox compared with the original, im 99.99% certain theyre the same, due to same ports, same volume etc, just a different shape to match a stack of HD15s
Peace
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2009 at 12:45am
Letterbox measured slightly lower response.  Rog said it was prob due to the larger port area in contact with the ground plane.
jamwa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jamwa Quote  Post ReplyReply Direct Link To This Post Posted: 07 April 2009 at 11:11am
is there any difference in performance with this version over the RM design...
Sound, Light, Projection, Display, Cameras and production support
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 07 April 2009 at 6:42pm
Um, did you read the posts before yours?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jamwa Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2009 at 6:18am
hhhmmmmmmmm
hond View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hond Quote  Post ReplyReply Direct Link To This Post Posted: 11 October 2009 at 12:42pm
does the Void V18-1000 fit?
Dougies Music View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dougies Music Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2009 at 12:58pm
Seriously?
Have you read the thread in the link above?
"4mm clearance either side of a void v18-1000"
Nicely answers your question right there...
jonminns View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonminns Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2009 at 3:08pm
Unless your build is 8mm out, in which case it won't fit
4 ohms is for wimps
This page was generated in 0.234 seconds.
