How many X15 for two X1 by side? |
Jogge
Registered User Joined: 09 August 2004 Location: Belgium Status: Offline Points: 63 |
Posted: 02 August 2005 at 5:28am |
I use the X1's with X12's on top for dance, rap, hiphop music with one X12 per X1.
The crossover frequencies are set to 90Hz and 1.8kHz which gives us a nice warm sound. The X1 X12 combination is not very suitable for techno though ... update: Forgot to mention i've set the HPF on the LMS to 35 Hz for the X1. Edited by Jogge |
Always listen to experts. They'll tell you what can't be done and why. Then do it.
Timebomb
Old Croc Joined: 11 October 2004 Location: Lancaster Status: Offline Points: 2716 |
Id go for it depends for the music being played and where the weight of the kick drum is.
norty303
Old Croc Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8806 |
I think i'll go for 80hz....
Who's next?
And is there a prize for the closest? |
Tom Umney
Registered User Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 4954 |
I think 100hz cross over point would be better.
nuendo
Registered User Joined: 13 August 2004 Status: Offline Points: 16 |
I think I will cross near 70Hz
norty303
If you've got 2 X1's per side then 4 X15's should be enough. You might even get away with 2 depending on how high you cross Edited by norty303 |
nuendo
For two X1 by side, how many X15? Thank. |
