  New Posts New Posts RSS Feed - DMX XLR to Stereo Jack
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Topic: DMX XLR to Stereo Jack
    Posted: 23 May 2009 at 3:06am
Well the TRS Jacks won't matter but the XLR to TRS might.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2009 at 10:19pm
fair enough ... tho doesnt matter either way appart from having the insulation the right colour.... long as 1 goes to 1, 2 -> 2, 3 -> 3 etc its gona make the same connection.
there be a lot of cables in plymouth coloured wrong now... Clown
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2009 at 1:30pm
It's an Abstract Futurescan II/III Controller which goes XLR to Jack to the first Futurescan II DMX 150 and then stereo jacks between all the heads.
I'm guessing the stereo jacks are for DMX.
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2009 at 7:59am
Originally posted by ceharden ceharden wrote:
Pat, please start checking your facts before posting.
For DMX the convention is 1: Ground, 2: Cold 3: Hot.  ie pins 2 and three are reversed with respect to audio.
For the jack connection (is it an NJD unit by any chance?) it depends on the individual unit because using a jack connection is non-standard.  Try an ordinary audio XLR -> balanced jack convertor.  If it doesn't work add a phase reverse (swap pins 2 and 3) and try that.  You won't hurt anything by having pins 2 and 3 reversed, it most likely just won't work at all or behave oddly.
+1
If it's for a NJD Datamoon it is wired Tip hot, ring cold, sheild ground (I doubt NJD swapped their system for any other products but you never know...).
PS are you sure its a dmx input? 1/4" jacks get used for all sorts in the world of lighting (dc output, strobe trigger pulses etc) be a bit carefull if its a bit unknown.
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2009 at 3:35am
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2009 at 3:28am
Ah so it's a standard audio style cable :)
Cheers mate
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2009 at 1:41am
xlr is pin1 ground, 2+, 3-
jack is tip+, mid -, base ground, like with audio.
some units are sometimes wired differently, but that will be specified in the manual. i just gave you standard wiring.
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2009 at 1:24am
Hello,
How do I wire a DMX cable that goes from 3pin XLR to Stereo Jack?
This page was generated in 0.093 seconds.
