  New Posts New Posts RSS Feed - Advice on Porn horn System (G subs?)
B.F.G View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B.F.G Quote  Post ReplyReply Direct Link To This Post Topic: Advice on Porn horn System (G subs?)
    Posted: 26 June 2009 at 1:20am
G'day.
I've been looking to build a nice PA for some time now, but I have been detered by slightly complicated builds and what not.. Since checking out the Porn horns though I have gain confidence through the apparently simple build!
As these boxes do not extend as low as one might like i've been trying to work out what style of subs would suit my applications best, whilst sticking to the "simpler construction" mindset.
Currently i'm thinking G-Subs would be my best bet. 2*GSubs per Porn Horn per side, or perhaps 3*GSubs with 2*Porns Horns per side.
Applications will include medium to largeish band PAs, and Dance music (Dubs, D'n'B, Jungle..).
What expereince or wisdom does the greater forum have to offer? Is this a workable system, or would I find better results with another combination?
Jake_Fielder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2009 at 3:19pm
one thing to consider is that porn horns can cover alot of subs so even 3 gsubs might not need 2 porn horns, also i think you still might be better off with a seperate kick section, 15" reflex maybe?
I dont really know alot about porn horns, im only posting because so far no one else seems to be able to help....
Edited by Jake_Fielder - 30 June 2009 at 3:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote B.F.G Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2009 at 5:05pm
After discussions with a friend we came to the same conclusion regarding kick boxes.. Perhaps 2 G subs and 2 HD15s per Porn horn?
Anywho.. Ta for the reply. I am still digesting all the options!
