  New Posts New Posts RSS Feed - A Recone Guide
A Recone Guide
 Post Reply Post Reply Page  123 10>
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
JYSE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JYSE Quote  Post ReplyReply Direct Link To This Post Topic: A Recone Guide
    Posted: 08 May 2021 at 9:04am
Is this available in PDF format
guig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote guig Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2017 at 4:12am
Clap
komotive View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote komotive Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2016 at 8:54am
Are there any other glues people have used without issue?
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 04 December 2015 at 11:13pm
i would welcome something 1/10th the price of the loctite one alright!
MattStolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattStolton Quote  Post ReplyReply Direct Link To This Post Posted: 04 December 2015 at 12:52pm
I have been using Loctite 4105, as a "black" super glue (ethyl cyanoacrylate); however, it is hideously expensive. Mostly for dustcap, or other "visible" joints, where the original was a black finish, or where the dust cap join is sort of flood filled.
Found this, and wondered if anyone had used it?
Looks to be very similar spec to 4105? But 1/10 of the price!!
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 20 November 2015 at 2:23am
Clap
midas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote midas Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2015 at 4:13pm
Has anyone used Gorrila glue on spider and basket? Or shall I pop to screwfix for some Evostick?
In bass no one can hear you scream!
Jubone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jubone Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2014 at 6:37pm
Thanks Joe and to everyone else who took the time pass on their wisdom on this forum. I went for it and the driver is working again. :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jubone Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2014 at 6:35pm
Yeah, got ya
brokenjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brokenjoe Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2014 at 6:31pm
no, i mean if it goes in  and can move freely without the shims i'd have thought it'd be ok..
error 404
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jubone Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2014 at 6:20pm
Ok, I'll try another dry run. On the previous one I had all the shims in place first and then eased the cone into place, so your saying put the cone in and then put in the shims, I'll give that a try on a dry run then. Thanks for that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brokenjoe Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2014 at 6:11pm
with the shims it should be pretty tight, especially the last one but you shouldn't have to force it..
i'd say if, without the shims in, that it moves fairly freely it should be ok.. i'd do the recone if i were you
error 404
This page was generated in 0.215 seconds.
