  New Posts New Posts RSS Feed - one sub per side
one sub per side
pfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfly Quote  Post ReplyReply Direct Link To This Post Topic: one sub per side
    Posted: 02 September 2009 at 10:04pm
How about Arcline and Stasys X? and accompanying midtops of course...
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2009 at 7:33pm
A good sub is a good sub period. The Hog is a great Sub. The upper bass/mid cab would have to be well thought out.
Saul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saul Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2009 at 7:06pm
Originally posted by Tony Wilkes Tony Wilkes wrote:
Simple solution, "Hogs" if you can handle the size/weight.
I was at a  venue a few weeks ago with just 3 in use and an absolutely unbelievable amount of air movement. Stick in some void 1200's and jobs a good-un
Tony
HOGS and techno ????   Dead
Jake_Fielder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2009 at 6:56pm
what about 1x 6 WSX stuck together, one of those perside would do the job
kiriiz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kiriiz Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2009 at 5:55pm
Big Bertha. One per side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2009 at 4:11pm
MEATGRINDER!!
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2009 at 10:54am
Tony
+1 I loaded mines with V1000 never really seen the use of more than 2ps( 4) 2alone work good Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2009 at 10:49am
Tony
Disco Stu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2009 at 9:59am
If you want to use a single horn per side its either going to be rather large, or you would probably be best off compromising on full horn loading and going for something like a 15" tapped, or ported horn.
Stu
All you need to know is:
Sensitivity + Power Handling - Power Compression = Max Output
My acts:
www.myspace.com/thebowiexperience
www.myspace.com/scheisseelektronisches
breakdabeat pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote breakdabeat pete Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2009 at 12:47am
if your only going to be using 1 bass bin per stack and want to go horn loaded i think you will have to have it in 1 single mono stack to make the horns couple
what type of tunes do you play too?
٩(̾●̮̮̃̾•̃̾)۶
ಠ_ಠ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ಠ_ಠ Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2009 at 12:21am
a big varierty of techno gets played and whatnot... some is rly kicky some just booooom... i want it all to sound good.  i also by nature prefer more mystical trancey things outdoors and way more kicky electro indoors which influenced my decision on some GRIZZLY horns... they just fit from how i describe my indoor vs outdoor music tastes
ಠ_ಠ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ಠ_ಠ Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2009 at 12:19am
Edited by ಠ_ಠ - 02 September 2009 at 12:22am
This page was generated in 0.156 seconds.
