  New Posts New Posts RSS Feed - Minidrive programming - help required
st3fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote st3fan Quote  Post ReplyReply Direct Link To This Post Topic: Minidrive programming - help required
    Posted: 11 April 2021 at 11:11am
I know this is an old thread, but I stumbled upon it while having the same problem ... Damn these things can be tricky to program if you've forgotten how Cry  Every year I lean how to then forget .. and then spend hours trying to work out the menu systems ... but as every year, I get there in the end.
Just programmed a Omnidrive 355 and a Minidrive 334 ... got stuck in X-over mode and couldn't for the life of me remember that it needed to be in EDGE mode.
But once you workout the damn menu, it is dead easy ... AS I FIND EVERY YEAR LOL
I think I might just start putting in monthly reminders in my calendar, just to go play with the settings and keep it in my head so I don't have to fight so hard when I really do need to do a full reprogram.
Good luck to any and all people out there who keep hitting there heads upon the setting up process!
Edited by st3fan - 11 April 2021 at 11:12am
Safetyman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Safetyman Quote  Post ReplyReply Direct Link To This Post Posted: 05 October 2009 at 8:48pm
Thanks Guys,
I think I have it now, all bar the shouting.
Cheers.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Safetyman Quote  Post ReplyReply Direct Link To This Post Posted: 05 October 2009 at 8:46pm
Originally posted by ceharden ceharden wrote:
Bandwidth is basically the inverse of Q.  It's done in octaves.
A bandwidth of 1 is one octave so if you have your EQ at 500Hz, it'll be roughly 500Hz wide (eg 250-750Hz).  A slider on a graphic is 1/3 of an octave so if you want to do an EQ that wide, set it to about 0.3.
I'm in Southampton.
Hi Chris,
Thanks for the info, much appreciated and thanks for your help.
Cheers.
darkmatter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darkmatter Quote  Post ReplyReply Direct Link To This Post Posted: 05 October 2009 at 4:02pm
might help to ensure that the unit is in 'xover mode: edge' and 'mono' setting from the 'utils' menu. otherwise one moves when you set the other and the unit tries to do some phase compensation too.
demanddeepbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote demanddeepbass Quote  Post ReplyReply Direct Link To This Post Posted: 05 October 2009 at 2:56pm
If you're a bit computery the easiest way to set these up is using the London Architect software available off the BSS website. It gives a nice pictorial diagram of what's going on and is far less cryptic than the front panel controls. You'll need a null moden cable and a computer with a serial port.
"These amps go up to 11"
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2009 at 11:03pm
I'm in Southampton.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Safetyman Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2009 at 10:50pm
Hey Chris,
it seems to have worked fairly well apart from the bandwidth. What should  that be set to, please ?
Where are you based on South Coast , as a matter of interest ?
Cheers
PS It was partially locked-out Robbo, thanks
Robbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2009 at 8:09pm
Is it all fully unlocked?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2009 at 5:32pm
Sorry, but I'm still not sure exactly where you're having trouble.  Saying you've set up Linkwitz-Riley filters suggests you've made it to the crossover settings but you say you can't get in to edit them.
You can get to the settings for each output by either pressing the gain trim next to that output or by pressing the large rotary encoder which will cycle through them.  If you have the unit in stereo mode (in the utilities menu) you will only need to set up two of the output channels because they'll be ganged together.
Once you're editing an output you can navigate using the 4 way pad.  Lo Freq is the lower crossover for an output so for the bins that might be 40Hz.  Hi Freq is the upper crossover so for the bins set that to 120Hz.
For the EQ, it's at one end of the parameters for the outputs. When it says Eq1S on the left you are editing the EQ type for EQ number one.  Set that to Bell. Go one parameter to the left I think using the pad and you'll get to set the frequency, next one will be gain and then the next one will be bandwidth.  If you move another position it'll insert a second EQ so you'll probably get Eq2S which will be the EQ type for EQ number 2.
Are we getting anywhere?
Manual is: http://www.bssaudio.com/product_downloads/User_Manuals/fds336Tum.pdf
TRE4U2NV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRE4U2NV Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2009 at 5:30pm
depress the big black thumbwheel and then use the other up down left right button to scroll to desired function then adjust as you please
ps never used a mini drive but asume its set up like the omnidrives
IM SO SECRETIVE BUT I CANT TELL YOU WHY
Post Options Post Options   Thanks (0) Thanks(0)   Quote Safetyman Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2009 at 4:43pm
Hi Guys,
Thanks for the offers of help, much appreciated.
I have set-up the basics for a four box system, 2 tops and 2 bins running in stereo with Linkwitz-Riley filtration, but cannot see how to get in and set a 120 hz crossover between the two. Also, I need to get in and set a 5db cut at 315 hz for the tops in the outputs. These are all recommended by the manufacturer( HZ ) with the crossover at 120 as a starting point.
Cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2009 at 12:19am
I'm kind of nearby.  The minidrive is pretty straightforward though, I'm sure we can talk you through it on here.  Can you be more specific about the problem?  Can you see the crossover settings and edit them?
This page was generated in 4.844 seconds.
