21" FLH |
Balázs1981 ![]() Registered User ![]() ![]() Joined: 11 December 2022 Location: Hungary Status: Offline Points: 10 |
![]() ![]() ![]() ![]() ![]() Posted: 17 March 2023 at 6:15pm |
Only the baskets B and C, the rest are self-developed.
VECTORDJ ![]() Registered User ![]() ![]() Joined: 11 June 2006 Location: United States Status: Offline Points: 489 |
B and C has a 21 Folded Horn Bass Plans on Their Website....Worth a Look....VectorDJ
új 21"-es altávcső
https://www.youtube.com/watch?v=aLk3oci2vZM Edited by Balázs1981 - 15 March 2023 at 9:13am |
Már nem kevlár ,carbon 1200w rms 21" hangszóróval. Carbon 21" 900/1800/3600peak 135mm voice coil, 25mm magas tekercs, kivül belül tekercselt. Tesla szeleppel készül.
https://www.youtube.com/shorts/cTsublz1thk https://www.youtube.com/shorts/0weHvozxzFc
Porkolab BH 121 FLH. Ezt mi készítjük. Már PS Audio névvel. 21" Carbon fiber woofer.
Edited by Balázs1981 - 15 March 2023 at 9:35am |
paulus ![]() Old Croc ![]() ![]() Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3144 |
pretty good if you want to shift some air below 40, otherwise stick to 12, 15's and 18's+1
exactly what we found
TRENDSETTER SOUND SYSTEM
airbell ![]() Registered User ![]() Joined: 11 June 2009 Location: Berlin, Germany Status: Offline Points: 284 |
Does anybody knows if the 108dB from the ts-42 are for 1/2, 1/4 or 1/8 space??
And if its for 1 speaker or more?
![]() coz the el-36c is claimed to have 106dB but at the prosoundweb shootouts
he didnt make a impressive appearance and didnt seemed to have
really 106dB 1w1m in general.he had a lot less output below 50hz than lab-horn in single...
DjMidKnight ![]() Registered User ![]() Joined: 31 August 2009 Location: Abq NM Status: Offline Points: 298 |
no they arent shorter to reach the same cutoff. as a result of the larger diameter of the driver the horn is actualy longer. a TS 42 is ALOT bigger than the ab36 is. however its also got larger wheels and a bar handle so its actually easier to move aside from lifting it.
Ibex ![]() Young Croc ![]() Joined: 27 May 2009 Status: Offline Points: 1013 |
What are the advantages/disadvantages of loading a horn with a 21"?
Is there only an approvement of higher sensitivity by reason of a bigger Sd? Are 21" horns shorter than 18" horns to archive the same cut-off? |
Yes, you are right!
Now I can remember that I already saw the new Cerwin-Vega! TS-42 on the Pro Light & Sound fair this year in Frankfurt... ![]() Bummer, that I had no chace to hear it at full power, only silent mode, but it seemed to play forsooth as deep as what the specs assure, but I'm not sure enough. http://forum.speakerplans.com/new-cerwin-vega-horn_topic23859&OB=ASC_page1.html Edited by Ibex - 16 October 2009 at 4:39pm |
im not sure i know that vega has a 21" out now also that they claim can do 144db all by itself
