186 Hole cut Diameter? |
Tapeworm ![]() Registered User ![]() Joined: 11 August 2008 Location: Bristol Status: Offline Points: 242 |
![]() ![]() ![]() ![]() ![]() Posted: 26 February 2010 at 2:35pm |
When I built mine a couple of years back, I used the measurements off the manufacturers speck sheet and they were fine!
The Builder ![]() Old Croc ![]() Joined: 03 January 2010 Status: Offline Points: 3107 |
Got blown ones here. I'll TRy and remember to measure tomorrow.
markie ![]() Old Croc ![]() Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4553 |
I've checked an older data sheet (from when PD were in Cornwall), plus 3 other PD 18" that use the same chassis and all state 414mm hole for front mounting. But they could all be wrong.
_banksy_ ![]() Registered User ![]() Joined: 18 January 2010 Location: Ireland Status: Offline Points: 31 |
I will be cutting the hole this weekend. can anyone else verify this is the correct size. just making sure!!
BreakBeat!
Thanks For pointing that out.
BreakBeat!
djeddie ![]() Old Croc ![]() ![]() Joined: 26 April 2004 Location: Bristol Status: Offline Points: 4119 |
Well according to the PD data sheet (picture at bottom right hand corner) it's 414mm. But don't quote me on that.
Hey,
I have ordered my PD 186 For my 186 Horn I am Building, However I want to Cut the intalation hole for the speaker in my Ply before it arrives. What is the Diameter or radius for the hole to be cut? Cheers, Will |
BreakBeat!
