6th order BP kick section |
Post Reply | Page 12> |
fourway hornloaded
Registered User Joined: 16 March 2014 Location: Hamburg Status: Offline Points: 60 |
Posted: 18 March 2014 at 8:26pm |
I agree with Mark, the driver should have a Qts around 0,3 and a lowish BL around 23, that makes the response nice and smooth. I think that the 0,2 Qts high-fs drivers that Johan mentions are more for pure horns without a front chamber. They'd make a peaky response in a BPH. I made a pair of 6th order BPH based on L15P200AK, but they were rather aimed at low extention.
As to 'real kick bins': they're all 4th order band pass horns, Turbo TMS, F1, HD15, so if you like that sound, go for it. They all have front chambers, otherways they wouldn't play that low. A straight 15" horn without a front chamber kicks like madness (think Martin MK1) and I can understand that people find that sound way better than a BPH, but then the only thing that makes it play lowish (70 Hz) is horn length. |
PolymorphicMark
Registered User Joined: 27 May 2004 Location: United Kingdom Status: Offline Points: 444 |
Thank you very much JD01 for taking the time to write such an informative answer. I fully understand what you are saying now, always nice when learn something meaningful.
Free to do what i WANT
JD01
Young Croc Joined: 23 August 2004 Status: Offline Points: 819 |
It's not the group delay as it only displays how long it takes till the signal will be coming out of the system. It can be compensated by delay as long as the group delay over frequency diagram won't be a wild ride around the crossover frequency. It is the decay time of the resonator. A resonator is a very high Q system, that means energy will be stored in and then put out of the resonator, and this won't happen in an instant, especially the "puting the energy out" will take some time AFTER the original signal stopped and even AFTER group delay time has passed. What a resonator does to the original signal is NEVER a good thing, it's always a degradation. Below 60, 70, 80Hz it is acceptable, but still not great. Above 80Hz it's just ugly compared to real "kick bins".
Most double-12 tops are tuned to 80Hz or below, and crossed over around 120Hz. That's ok in my opinion, still there is coming some "noise" coming from the resonator. Stuffing the port for top usage comes to mind. Ported tops tuned to 100Hz or above are just flawed designs, I wouldn't like to use them at all. |
PolymorphicMark
JD01, when you say how close to the original signal do you want to stay, what do you mean? Are you saying that because the sound is coming form a port the phase shift/group delay effects the kick bass. If this is so, then on a standard bass reflex box with say two 12's a large proportion of the sound will still be coming from the port, so there will still e similar phase shift I Think. I have a 6BP with a group delay of <7ms form about 80Hz - 130
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2582 |
I have had some problems in the past with Doppler effect in a design similar to this
I don't say you shouldn't try, just make sure the speed of air in the ports is as low as possible so there won't be a lot of air moving along with the mid and HF, atrough I am still not shure that this is the corect way to cure the problem after some recent tests. This can also be observed when running stupid amounths of sub right next to midtops above a certan limit everything starts to sound muddy when you unmute the sub section. Edited by Mircea Bartic - 11 January 2011 at 9:40pm |
http://www.facebook.com/nexus.acoustics.research Ex Nexus_3 |
JD01
I heard lots of BP6, but I never liked any of them above ~80Hz. All kick BP6 have failed to impress me, I wouldn't consider using such a design for kick. This is not a matter of taste, but a matter of how true one wants to stay to the original signal.
PolymorphicMark
I've found light cones work well in 6BP that need to reach mid kick bass/mid bass frequencies. I used the 18sound 18ND930 in 6bp (light cone for an 18) and measured -3b 47hz - 136hz. Sounded good crossed at about 120hz.
I would probably chose the MB15N351 because of it's very high efficiency (5% i think of the head), plus high fs, and Qts of 0.28 to 0.32 work well in 6bp tuned in the kick bass region.
darkmatter
Old Croc Joined: 26 February 2005 Location: LDN Status: Offline Points: 2425 |
I was going to say exactly what CSG said, seems a waste to limit yourself to the sensitivity of the single driver kick section when you have such a potent mid-top combo.
Not sure a BP6 alignment would have the ideal transient response/group delay for kick, and using such a small bandwidth might be a headache in terms of integrating it with the boxes above/below?
csg
Old Croc Joined: 17 September 2007 Location: bedford Status: Offline Points: 6086 |
could another idea be to take the meyer aproach and relex load the rear chamber of the 12" section - they do this on the MSL4 to good effect, that runs down to 65Hz ewith just one 12" and 2" per cab
csg
I think your biggest problem will be in sensitivity - i think it will be hard for the bp6 section to keep up with the rest of the box
but, certainly an interesting idea
lukam
Registered User Joined: 15 April 2009 Location: Slovenia Status: Offline Points: 46 |
From what you say the B&C 15NW76 would be nice. FS 42, Qes 0,23, Qts 0,22, Vas 130L, Le 1,25mH and Xmax 8mm.
The simulation also looks good for rear chamber 60L at 70Hz and front chamber 20L at 140Hz. But measurements will tell. I dont know what compression ratio you mean? For the porn horn I dont know. The porn horn plays down to 130Hz so I would cross over them around 130-160Hz must see. The low cut off for the bandpass would be arround 80Hz. I have 1000W availible to power the kick section. I dont know how will a BP sound compared to a say USB, what you guys think? Regards Luka |
mobiele eenheid
Old Croc Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
Ultimately you're probably looking for drivers with low Qes/Qts (0,2-0,3), high Fs (45>), lowish Vas (<130 L)and lowish Le (~1,3 mH). High Xmax (7mm >) and 3"VC or bigger are always welcome.
What's the compression ratio on the horn part, what's the crossover part and how much are you going to power these supposebly?
Regards Johan
