  New Posts New Posts RSS Feed - 64bit worth it?
64bit worth it?
minaximal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote minaximal Quote  Post ReplyReply Direct Link To This Post Topic: 64bit worth it?
    Posted: 24 February 2010 at 5:11pm
hi, my 32bit windows 7RC expires in 6 days, so i'm wondering if i should bother trying out a 64bit OS again?
last time i tried a few of my progs didn't like it, but i dont remember if i attempted to run in admin host thing mode before..
anyway, it's for a lenovo t61 laptop, with max of 4gb ram, i've never found 32bit to be too slow or anything, and i have alot of odd software, which may not run well on 64bit, so how have you found it and is it worth it?
cheers
Subs + Barges = :)
www.metaacoustics.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2010 at 5:32pm
Unless you have apps that you absolutely know benefit massively from working in x64 (CAD apps perhaps) then there's basically no point unless you have more than 4GB RAM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote minaximal Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2010 at 7:21pm
cool, cheers, that's settled it then, thought something like that would be the case.
i'll stick with using an x86
thanks toasty
Subs + Barges = :)
SoundAT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SoundAT Quote  Post ReplyReply Direct Link To This Post Posted: 25 February 2010 at 5:07pm
x86 apps do run faster in x64 Environment...
x86 apps can only access 3.5GB Ram if you have 4GB it might be beneficial to get x64
as toasty said the real benefits are only massively noticeable if you are running x64 code(and drivers)..
If you can get x64 drivers for all of your hardware then i would go for x64, if you stay x86 then you will limit yourself in the future... x64 apps are coming out now. might be worth investing...
subbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote subbass Quote  Post ReplyReply Direct Link To This Post Posted: 25 February 2010 at 6:16pm
win7 64bit is backwards compatible with 32bit programs
