  New Posts New Posts RSS Feed - MT/limmer
MT/limmer
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Topic: MT/limmer
    Posted: 26 October 2018 at 6:06pm
the limmer 308 aint exactly new at all afaik.. unfortunately they are too shallow/small to meet "usual" kicks properly imo - i would go with Bens/Bees take on "porn horns"/"SP12s" if i would consider such a 4way setup..
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2018 at 8:50am
Five years later speakers still going strong, now They’ve come up with something new
and this one too I want to play with these this winter
Post Options Post Options   Thanks (1) Thanks(1)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2013 at 7:09pm
it´s  a good cab just don´t put three per side in a thin room cause the top spreads quite much. two per side max.
hulkeh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hulkeh Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2013 at 6:56pm
Nice, thanks :)
Been thinking about the mt limmer combo but just weighing up costings and things :s
What's your opinion on the cab? Would you recommend it?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2013 at 5:41pm
12" run from 140-around 950-1000 the Ciare 6.38MR3 runs from 900-3k then BC. DE25 does, the rest you can always fine tune from there if you don´t like the sound .
Francis
Post Options Post Options   Thanks (0) Thanks(0)   Quote hulkeh Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2013 at 4:51pm
Originally posted by Father-Francis Father-Francis wrote:
the cabs are Pd123 in the 12" , Limmer 042, Ciare 6.38MR3, BC.Speakers DE25, I´l say each cab´s about 1150£ when done we´l be making wheel-boards F1 style to move them around .
What crossover points did you use?Clap
Pirlo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pirlo Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2011 at 10:53pm
update?!?
Who the fu&k is Mr. Phanton, and why he has so much power!?
Nachural View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nachural Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2011 at 5:20pm
I’ve been playing around with the limmer combination for a while now. Small rear chamber volume is definitely the way to go. Sounds sweet in short throw applications.
it's all just cardboard and magnets really
huhts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote huhts Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 10:51pm
Thank you! That's what I was thinking also. The limmer p2 and p3 designs (speakerstore.nl) just have some bigger enclosures behind ciare that confused me a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 10:07pm
Thanks for the info Dom that will save us some time , Thumbs Up
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 9:52pm
When I did my Limmer/Porn horns the back box for the 6.38 was as small as they could possibly be.
The back box was basically the same internal diameter as the baffle cutout and the same depth as the driver.  The back of the back box was an aluminium plate that acted as a heatsink for the magnet.
We did some modelling of the driver and horn in Akabak and it wanted a tiny rear chamber, of the order of 0.5litres...
I'm probably going to stick them up in the for sale section at some point if anyone's interested...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 9:25pm
Originally posted by huhts huhts wrote:
How big/small back box volumes have you used for the ciare 6.38mr2 in limmer042?
Did a few jobs without any back box , and notice that the sound from the 6.38 was very low at 15-20 metres so am making some moulds  different sizes and will let you know what size sounds best,
