tannoy t 12 an t300 |
DMorison ![]() Old Croc ![]() Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1527 |
![]() ![]() ![]() ![]() ![]() Posted: 09 November 2021 at 1:48pm |
I think you need at least 10 points (ie posts) to enable the option to upload directly to the forum - presumably that's to prevent spam. Once you have those points, you can upload by hitting the relevant button in the post editor. /this first button takes you to the Full editor: ![]() Then this one lets you do the upload: ![]() However, the forum software does compress images, so if you want high quality this isn't always the best option. Otherwise, you can host on an external site like imgur which I've used for that example above and paste the bbcode for the images into your post to make the pics show up here.
Edited by DMorison - 09 November 2021 at 1:58pm |
youthman1979@gmail.c ![]() New Member ![]() ![]() Joined: 09 November 2021 Location: Kansas City Status: Offline Points: 1 |
You ever seen these before ? Tannoy T-300 with 2 15” subwoofers non concentric . Tannoy Canada with full range and sub in inputs both XLR CONNECTION
Edited by youthman1979@gmail.c - 09 November 2021 at 12:59am |
Nitz V1505 ![]() Old Croc ![]() ![]() Joined: 16 September 2009 Location: UXBRIDGE Status: Offline Points: 1719 |
& THE TOPS LIKE LIGHTNING..... |
brokenjoe ![]() Old Croc ![]() Joined: 31 May 2009 Location: Birmingham Status: Offline Points: 3709 |
really liked my t300s had 8 altogether, but not a brilliant throw on them..
Jasonstry ![]() Young Croc ![]() ![]() Joined: 11 September 2007 Location: Cannock. J11 M6 Status: Offline Points: 1367 |
T12 is a wedge shape, I use 4 of them for monitors! They aren't the same power handling. The T12 is 200W/400W/800W and the T300 is 300W/600W/1200W. However the T300 is more sensitive than the T12, so goes quite a bit louder. It has a wider dispersion, 90 degrees compared to 60 degrees. The T300 is a bit bigger and heavier. I think thats it.
Andy
I believe the t12 is a trapezoidal cab and the t300 a wedge stage monitor shape cab.
They do sound nice being a co-ax and all that point source mellarky and no one has done this style speaker for longer than tannoy.
7567kelsall ![]() Registered User ![]() Joined: 20 October 2009 Status: Offline Points: 70 |
hi all can any 1 tell me the difference bettween the tannoy t 12 an t 300 passive speakers both dual concentric both the same rms both a 12 ,, driver i av a chance of buying either would like to know which are best for my application . solo artist so they av to be vocaly gud or i could get a pair of t i 8,,
