Tutorial on Loading the PD 186, Please? |
cnc123 ![]() Registered User ![]() Joined: 23 December 2009 Status: Offline Points: 108 |
![]() ![]() ![]() ![]() ![]() Posted: 21 March 2010 at 11:17pm |
m6 has a braking strain of aprox 1/4 ton 4 is enough to buckle any chassis
pd use to put m8 machine bolts like hex heads, in the carton a bit of marketing me thinks + m6 you can be a dork on the drill + you can fit many other spks (but only if you can drill on centre) |
_banksy_ ![]() Registered User ![]() Joined: 18 January 2010 Location: Ireland Status: Offline Points: 31 |
Yes actually M8 is the correct size for the pd 186
BreakBeat!
Saul ![]() Old Croc ![]() Joined: 15 June 2007 Status: Offline Points: 5912 |
hmm thats odd - when ever ive mounted a PD1850 ive managed m8? oh well....
studio45 ![]() Old Croc ![]() ![]() Joined: 16 October 2007 Location: United Kingdom Status: Offline Points: 3846 |
not quite, the holes are just less than 8mm, i used m8's to mount some of mine and had to drill them out a bit. m6 and a washer will do fine.
actually i think pd186 chassis take M8 bolts.
RUS ![]() Old Croc ![]() Joined: 02 September 2008 Status: Offline Points: 3469 |
you should use m6.
Thanks,
So should I use M8 or M6 T-nuts and bolts? |
BreakBeat!
go though the six outside holes.
Hi,
I have the plywood routed out to the correct size so that the 186's foam circle rests in a perfect position around the edge of the hole. Now when rear loading I just need to know which holes to bolt through, there is six holes for bolts and i think another six holes that are covered with foam on the speaker side, if using t nuts and bolts is the six holes enough to support it? any pics would help. cheers |
BreakBeat!
