  New Posts New Posts RSS Feed - series II P-Audio SN-12MB in X12
rossino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rossino Quote  Post ReplyReply Direct Link To This Post Topic: series II P-Audio SN-12MB in X12
    Posted: 17 January 2015 at 1:14pm
Hi jerronimo.
You wrote in a comment that you "SN 12 MB can get them for around 140,- euro a piece" Can you tell me where you can buy them at a such reasonable price? I want to replace the speakers in my line array system. First of all just in one and to see how it works.
Edited by rossino - 17 January 2015 at 1:24pm
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2011 at 8:12pm
this is what we have developed using SN10MB
http://www.forum.poweraudio.ro/viewtopic.php?f=47&t=10653
it is loaded with SN10MB , Selenium D220Ti  and PH1919 from P-audio
the passive crossover is our own design with electronic protection for the HF (faster transistors instead of slow lamps)
Edited by Mircea Bartic - 11 January 2011 at 8:12pm
Ex Nexus_3
Saturnus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saturnus Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2011 at 7:37pm
Originally posted by Mircea Bartic Mircea Bartic wrote:
Saturnus, have you tested the powerhandling?
No, power handling doesn't really interest me that much. Pretty much any well constructed speaker can take oceans of power. But also because I don't have an amp with enough power to actually really test it. My biggest amp is 300W into 8 Ohms, more than enough for almost anything, and not big enough to damage almost any driver except some high frequency drivers with improper filtering.
Sound quality is much more important to me given that it's supposed to reproduce the midrange spectrum and especially voices.
Power handling is more interesting for a bass speaker IMO.
EDIT: Let me interject here that many people focus way too much on having big and capable sub stacks. When it comes down to it really, any speaker system without a well sounding midrange will always sound bad no matter how good a bass range it has.
Edited by Saturnus - 11 January 2011 at 8:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2011 at 6:03pm
We trew 1100W RMS for many nights at it and it only came back for moreTongue
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saturnus Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2011 at 3:39pm
If they're anything similar in sound quality to the 10" version they should be fantastic. The SN10MB series II is the best midwoofer I've ever heard, regardless of cost. It's quite simply astonishing when it comes the clarity of voices, pretty much on par with my Fostex FE206 in BLH in that respect, and that's saying a whole lot actually.
EDIT: And to answer a previous question in this thread, the 10" version needed about a week of run-in 24/7 to loosen up so I'd expect the same from the 12" version.
Edited by Saturnus - 11 January 2011 at 3:43pm
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2011 at 1:13pm
nice. encouraging.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2011 at 12:42pm
You cant go wrong with bms. Comparing the build quality between paudio and bms, paudio dont stand a chance at all. I have a lot of bms drivers now having take over the complete Bold Audio production and no real comparison to be honest. Only advantage on the paudio side is the price. Not sure what the price is there, i got them for 85 us$ each.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2011 at 12:21pm
i'm just running ideas round my head at the moment.. no concrete plans. but in the next couple of months i may put something together for something: a pair of g-subs with fane xbs, and a pair of X12 type tops, with p-audio horns and comps (which i already have), and i'm thinking over the 12" drivers.
weight wouldn't be an issue at all, so if things are more expensive just because they're light, i'd go for the heavy...
with that in mind.. currently thinking about the BMS 12S320..
cheers anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2011 at 12:04pm
To be honest i didnt had a time to do it. Today i am cutting some plywood for the new Bold Audio BA12 model and i will try to do spare baffles.
Problem is that they dont fit in any of my boxes. They need few mm bigger hole.
What i can tell is that they are super light, they are nicely build, but from what i can see they have very stiff suspensions and i dont think they will go very low. Not sure that they can be used in a full range box.
I expect great results 80Hz and above. Maybe they need to run in a bit. Dunno. This few days will tell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2011 at 11:47am
well marjan, did you test them? i'm reading a lot about 12" drivers for X12 type boxes these days..
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2010 at 5:29pm
I have two of those new SNII series. Will test them next week.
lee500 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lee500 Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2010 at 11:32am
Thanks for sharing this post.This site is very helpful for me and others
