  New Posts New Posts RSS Feed - tapped118
tapped118
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Topic: tapped118
    Posted: 09 August 2010 at 9:50am
Originally posted by jamwa jamwa wrote:
very bored on a conference so started playing around with this design as experienced te Danley 18TH sub and speaking with the guys at danley they have used 6 a side on large 5000+ audience concerts to great effect - would this work - one question would the air blowing across the back of the driver effect the output.
Why did you change the folding lay out?
JDCutta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDCutta Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2010 at 9:37am
any updates with this design?
jamwa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jamwa Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2010 at 4:14pm
Sound, Light, Projection, Display, Cameras and production support
nobbybonez View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nobbybonez Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2010 at 3:48pm
Originally posted by rich_gale rich_gale wrote:
nice design.  i wonder if you could extend the horn length by creating a tail of extra horn in the biggest area of wasted space?  maybe 6" more.  in the same way the bassmaxx cabs have the driver slightly down from the start of the horn expansion.
you mean??
phear my paint skillzor :D
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2010 at 10:11am
are you talking about an offset driver arrangement?
doesn't that lower the upper cutoff frequency due to a certain notch filter effect?
kiriiz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kiriiz Quote  Post ReplyReply Direct Link To This Post Posted: 22 June 2010 at 6:35am
umm... how low can it go? Wink
asaa00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote asaa00 Quote  Post ReplyReply Direct Link To This Post Posted: 21 June 2010 at 11:02pm
goddamn winky smileys
staiper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 21 June 2010 at 10:26pm
nice design.  i wonder if you could extend the horn length by creating a tail of extra horn in the biggest area of wasted space?  maybe 6" more...
Wink
Just do it! ..or do not.. ;)
rich_gale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich_gale Quote  Post ReplyReply Direct Link To This Post Posted: 21 June 2010 at 10:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 21 June 2010 at 10:16pm
Originally posted by djyves djyves wrote:
do you have some more info on that?
Just slight moded TH115 to fit 18" driver ..
BTW ..very close original layout guess Clap
djyves View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 21 June 2010 at 11:55am
"If brute force doesn't work, you're just not using enough!"
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 21 June 2010 at 11:35am
Finally someone got close :-)
Nice one kardash :-)
