  New Posts New Posts RSS Feed - Amp's as12vdc to 240vac 50hz inverters?
noislinger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote noislinger Quote  Post ReplyReply Direct Link To This Post Topic: Amp's as12vdc to 240vac 50hz inverters?
    Posted: 17 July 2010 at 1:28pm
I wanted to buy a 12vdc to 240vac inverter for a diy solar/ wind power setup. It must basically just be a very simple amplifier with the output set at 240v. I'll probably buy a cheap inverter anyway but could i use my amps?
if a 50hz sine wave signal is amplified to 240v off a 12v battery, could it then operate some 240vac devices.
Any ideas of how it could be done, and what are the limitations.
could a void infinite8 run off 12vdc battery(bypassing the supply) and provide 240vac?
im sure there is a good reason for not doing this, but to me it seems like it should work?
josh
abeltronics View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abeltronics Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2010 at 3:37pm
There's no amp in existence that can chuck out 240V while running from a 12V supply.
You need a pro-sine or quasi sine inverter for what you want, depending on what load you're running.
http://www.abeltronics.co.uk - Electronic Engineers
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2010 at 4:16pm
The significance of a pure sine wave inverter will hit you quite quick if you use wind power a lot as modified sine wave inverters blow stuff up.....
My father has a place in spain which runs off solar/wind and his first (2500 euro) modified wave inverter got through 2 fridges in 18months...
He now has pure sine wave and the current fridge has celebrated it's 5th birthday....
