  New Posts New Posts RSS Feed - full system help
full system help
Insomnia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Insomnia Quote  Post ReplyReply Direct Link To This Post Topic: full system help
    Posted: 21 March 2006 at 10:31pm
hi,
the T18's of Mtls will go up 120-130hz no probs
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2006 at 10:38am
i could imagine maybey a 15" in between but im not too familier with the t18. how high does she go? the porns sound ok apparently down to 120/130hz so if she can get up to 130hz without problems then you should be ok. if not then something like a hd15 [well a few obviusly] inbetween to allow you cross at like 170hz
bassicaly is the t18 a sub or a bass bin?
paddyd11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paddyd11 Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2006 at 6:38am
hi there im looking intobuilding some of these but need a bit of info, i will be using them with either ev mtl's or t18's for medium to large halls and small outdoor systems. will these added with the above subs lwork as a full range system or will i need other boxes also. do they need to be run 2, 3 or 4 way etc thanks for your help
