  New Posts New Posts RSS Feed - New Sub-Horn plan?
New Sub-Horn plan?
Jay Lawless View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Topic: New Sub-Horn plan?
    Posted: 23 March 2006 at 4:47pm
Originally posted by 12345 12345 wrote:
Originally posted by Jimbo Jimbo wrote:
Have you modeled this on Hornresp yet?  Need to make sure your heading in the right direction before working on the folds.
If you have, I could have a go at the folds in AutoCAD for you.
Jim
no. i am a complete novice and just doing this as a bit of fun.
what would be involved in modelling it on horn response? if you could do the auto cad and what have you, i would be very grateful.
you'l never know if you'r horn is good at all intill you input it into hornresp. intill then you, nor any of us will be able to tell you that it's worth trying out. the drawing is looking better, but theres no inputs to go by. once you learn hornresp it should be easy to help you out after that. plus by supplieing atleast rough measures *incase you want to keep the design for copyright reasons* it will help others try to tweak the design slightly to help increase or decrease certain aspects of the design.
Previously known as NeverWinter
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist
Jimbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimbo Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2006 at 11:20am
Hornresp is pretty simple once you understand the inputs.  Search the forum on it and you'll come accross a lot of good info (including where to get it).
Jim
al_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote al_x Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 5:37pm
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimbo Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 5:05pm
Jim
al_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote al_x Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 3:46pm
@norty303 - as regards to your comment about the horn getting largaer and then smaller, i have made some adjustments. added about 250-300 mm to the height and changed the folds abit
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 2:47pm
Originally posted by ceharden ceharden wrote:
Um, it's getting a bit big!
Maybe we should spec required freq resp, and then arrive at the best way of acheiving it.
I personally think a WSX would be a good design starting point,
SNIP
Did have plan for WSX with internal dimensions here, but edited it
out so speakerplans.com doesn't get slapped for
encouraging copyright theft.. WSX internal here
SNIP
but with simpler driver mounting, access plate heatsinking, sensible 1850 compatible rear horn chamber, resulting in a final design with 8ft+ horn length, that does 38hz to 150 "flat", without over excursing driver. I wouldn't mind carting 4 of these around if I knew I was guaranteed 38hz, without ridiculous eq or blowing a few xmechs/xmax's every gig.
Edited by levyte357 - 20 March 2006 at 3:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimbo Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 11:44am
Do your simulations, decided on your compromises and when your satisfied, build a prototype.  This being said from someone who is in this as a hobbie.  Building them is more than half the fun.  If size doesn't matter (depends on who you talk to), why not?
If you have access to AutoCAD, Graeme has a very cool program for doing horn foldings on his sight.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 3:42am
Originally posted by Nexus_3 Nexus_3 wrote:
I see a whole lot of wasted space in there...
exactly why i said not to really go by those folds.
personaly i think it's a little much... but hey, who ever said you couldn't try you know...
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 3:40am
if thats your design! i wouldnt use the word sub!!
and the mouths to small.
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2006 at 2:56am
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2006 at 11:56pm
try something like this, though maybe not as many lines but something simular. try a HxD of 90.25cm high and 90.25cm deep. and also try a width of about 76.2-76.25cm, that should give you plenty of room.
Edited by NeverWinter - 19 March 2006 at 11:57pm
al_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote al_x Quote  Post ReplyReply Direct Link To This Post Posted: 19 March 2006 at 5:11pm
yeh thats what i thought.
its just a very first idea tho. i did it on paint in 5 minutes
back to the 'drawing board'
