What have you done to your soundsystem today? |
Post Reply | Page 123 58> |
Bams
Young Croc Joined: 08 April 2009 Status: Offline Points: 628 |
Posted: 22 September 2021 at 8:18pm |
Got myself an c-mark 2450 amp for again a round of small bitcoin-gains. The earlier in this thread mentioned devine will move up for mid-duties.
Rengade Project
Young Croc Joined: 12 December 2004 Location: United States Status: Offline Points: 601 |
as above
MUSIC SWEET,www.myspace.com/renegadeproject
Rengade Project
Yes they are, I already had 2 before and they perform well
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
Busy with some 8" tops (4 in total):
As you see, enough glue was used in the process Will be loaded with RCF MB8N251 and B&C DE360 on ME20 horn. |
toastyghost
The 10,000 Points Club Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10919 |
Those are great sounding amplifiers! |
Rengade Project
A few days ago we purchased 5 Studio R X8 and before that 4 Meyer MSL4a speakers. Also some mic cables.
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1293 |
Edited, can't be arsed.
Edited by concept-10 - 09 May 2021 at 8:49am |
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5175 |
I've benched Class D amplifiers for 6 years in addition to, Class AB and Class H amplifiers. This amplifier is not my first ownership of a Class D Amplifier. The K30 has already proven itself in the field for those who are not afraid to drive their amplifiers relentlessly. Seems like you are falling beyond on what's going on in the scene Best Regards, |
toastyghost
This is a Class D amplifier, yes? I hope you know how to bench this type of amplifier and document your process appropriately before you post utterly pointless results that might put other people off using them.
The K 30 arrived today. I powered it up just to make sure both channels pass signal on 120 volts.
Now, I need to buy a 120-volt receptacle to attach to the Hubbellock 600 volt plug. As this amplifier will be receiving 250-volt line voltage, I do not want to use the standard 120-volt receptacle (Offered on the amplifier) as that is against our electrical code.
Since the Hubblelock is only found in the industrial market, it eliminates any Non-Hubbellock home consumer plug inserted into the Hubbellock receptacle distributing 250-volts. The K 30 offers a maximum input line voltage rating of 270 volts. This is ideal as the amplifier should have no issues handling 250 – 256 line voltage.
You should see the bench test results of the K30 posted in the Amp Forum by the end of next week.
Best Regards,
I just ordered the K30 Amplifier. I bought it solely for low mids. However, once it arrives, I will put it on the bench and, post the measured wattage using a sinusoidal wave ranging from 100 Hz - 5 Hz. Once it arrives of course! Best Regards,
Edited by Elliot Thompson - 24 April 2021 at 5:50pm |
mk2_ginger_biscuit69
Old Croc Joined: 03 November 2008 Location: Brighton Status: Offline Points: 7801 |
today I did a quote for a sound system, which involved trying to remember what I would need to make a live gig happen. God its been a long time! Next challenge, how do you mix a band again? |
