  New Posts New Posts RSS Feed - any advices?
any advices?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Topic: any advices?
    Posted: 19 January 2011 at 7:51am
You will need a strait horn to go high enough to meet the 8's.
airbell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote airbell Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2011 at 5:55am
okay to ask my question more clearly:
how high does a 15" bandpasshorn with this driver still sound good?
how low you can use some 8" horn loaded tops (4+), long enough horn, still sounding good
with good spl?
thx
Post Options Post Options   Thanks (0) Thanks(0)   Quote airbell Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2011 at 11:27pm
if i want to build some 8"+1" horn tops,
several,
very narrow dispersion,
long horn,
go with 18sound 8m400  with a selfmade phase plug
and bms 4550,
and use some long 12" sub-horns like (similar to) eaw bh760,
do you think a 15inch midbass bandpass-horn could meet
the 8" nicely?
speaker for the bandpass horn would be
CPA15-1000.
the link doesnt work, but here some TSP:
qts 0,19
bl 25,3
vas 220
fs 31hz
hornresp shows very similar relults (almost identical)
to the usb!!!
maybe 2db more at 200hz and a roll of at 260hz
instead 220hz like the usb...(simulation in 0,5pi)
for the low-end its almost the same.
ah and i simulated the usb with rcf l18s800 (which i already built=)
im happy for any statements or opinions!
ps:
according to hornresp it would work if i use 4 or more 8"horns,
but i think for my taste the usb with 18s800 doesnt sound so well at ~180hz.
so do u think with the cpa15-1000 it could work?
thanks
Edited by airbell - 18 January 2011 at 11:30pm
