  New Posts New Posts RSS Feed - How low will 8x 186horn go?
spongebob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spongebob Quote  Post ReplyReply Direct Link To This Post Topic: How low will 8x 186horn go?
    Posted: 20 June 2011 at 8:28pm
Thread Jack :D
Could someone estimate 6x 1850's for me (Void V18 loaded)
Danke
tomschute View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomschute Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2011 at 7:46pm
Originally posted by Calculus Calculus wrote:
Learn to use horn resp. and you'll have a answer in no time.
unless you model the actual horn that 8 cabs creates horn resp will not paint an accurate picture at all.
Out to lunch... stableaudio@hotmail.co.uk
www.stableaudio.co.uk
Speaker Building Services
saladmanscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote saladmanscott Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2011 at 7:13pm
what is the SPL like with that set-up.  how do they sound?
Scott
Aztor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aztor Quote  Post ReplyReply Direct Link To This Post Posted: 06 April 2011 at 9:13am
Ok, i'm currently using 4x 186 at 48-150 hz.
The Builder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 06 April 2011 at 8:39am
I recon 45 to 120, never owned them though, only old CV similar, but that was many moons ago before dubstep ;)
It just is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aztor Quote  Post ReplyReply Direct Link To This Post Posted: 06 April 2011 at 8:15am
Thanks
Is there a rule of thumb? What should be suggested cutoff?
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2011 at 10:49pm
as low as you would ever need them to go
Actually very true.
All this sub 40hz stuff, 65hz is where it's at with a LOT of music.
Try a test tone and see
It just is.
mykey- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2011 at 12:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aztor Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2011 at 12:28pm
About 45 hz then. I can use it, but i thougt some had experience with 8 horns. Tongue
Calculus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calculus Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2011 at 12:53am
Always a compromise, You can't have everything...
Where would you put it all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aztor Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2011 at 12:04am
Hello
How low will 8 186horn go? Stacked 4 high.
