  New Posts New Posts RSS Feed - X1
X1
Andrew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Quote  Post ReplyReply Direct Link To This Post Topic: X1
    Posted: 18 October 2004 at 12:15pm
Feels like a good starting point ... ?
whitehousejamie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitehousejamie Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2004 at 11:07pm
16kw of sub mmmm
Mal X View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mal X Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2004 at 11:06pm
ah you are right indeed, when i sort out some cash i will buy 2 infinate 8's to run my X1's give them a bit morer and let the cause hell!!!
Mal, how loud was that!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitehousejamie Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2004 at 3:00pm
Yes, he uses the V18 driver, and runs the 4 cabs off a Network 4, giving 900watts to each driver. I assume they get crossed over at 80hz.
Jez_Ultra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jez_Ultra Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2004 at 1:00pm
Mal are u using the V-18 1000, and if so how much are you sticking into each x1, where are you x-ing them over?
Jez
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mal X Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2004 at 9:21am
should be good its more powerful and has a bigger coil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitehousejamie Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2004 at 12:05am
I wonder how this new Void driver that is designed specifically for bandpass cabs will sound in the X1
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mal X Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2004 at 12:02am
yeah i would say so but then mine have that bid void lump in them.
Hobbyist2004 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hobbyist2004 Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2004 at 11:27pm
Just a general question about the X1, what kind of sound should I be getting out of the box. Should I be able to feel the bass punch at 10 feet or just here enormous rumbles of bass? I'm using the C18-650EL driven with a QSC 2450. What kind of numbers per stack are needed? 2 or more I'm guessing? I had a chance to hear some EAW sb-1000's and they packed quite a punch at 10-15ft, is the X1 comparable?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2004 at 7:53pm
Did anyone get Pauls' jig for making the HD15 curve?
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2004 at 7:28pm
I'll let you know, busy building more kickbins at the moment....
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2004 at 5:20pm
And?
