  New Posts New Posts RSS Feed - WTF!?
WTF!?
TechnoChef View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TechnoChef Quote  Post ReplyReply Direct Link To This Post Topic: WTF!?
    Posted: 13 October 2011 at 5:40pm
Originally posted by slaz slaz wrote:
Originally posted by The Builder The Builder wrote:
Or very slightly loose RAM, deffo re-seat it.
True ...
I second that, some of the dells I see at work have serious build quality issues
slaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slaz Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2011 at 4:48pm
True ...
soundchippy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundchippy Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2011 at 4:34pm
I find it funny that it even booted this morning. pc wasnt even getting to the dell screen last night
The Builder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2011 at 4:29pm
It just is.
slaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slaz Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2011 at 3:47pm
Originally posted by soundchippy soundchippy wrote:
Gave the machine a try today. Booted into Bios, reset defaults (not sure if this did anything tbh), then ran the dell factory restore from the recovery partition. Woking fine now.  Confused
Thanks for all the tips.
Looks like
"Oh yeah - one more possibility - you may just have corrupted BIOS setup data (CMOS data)."
was probably a correct diagnosis then :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundchippy Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2011 at 2:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2011 at 8:53am
Two different issues. The updates, fine.
The flashing coloured lines are ram of some sort (or make sure your video cable is firmly attached).
RAM could be system or Video.
Make sure all RAM is seated propperly, if you have two sticks, try one at a time.
There are Dell diagnostics onboard to check RAM as said above.
It just is.
colinmono View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colinmono Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2011 at 8:04am
I've seen bad RAM cause similar issues.
If you can get into setup on boot (F2?) worth doing a memory test.
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundchippy Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2011 at 12:09am
thanks for the help. but no luck i'm afraid. on the phone to dell in the morning i think.
lucky really as i backed up all my data quite recently.
slaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slaz Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2011 at 11:00pm
thanks for the advice. i got half way through the dell datasafe thing this time before it crashed. just going to try a full restore if i can get it to works one more time.
If you want to get at your data, best to take the HD out of the machine, hook it up to a USB<->SATA adapter (or similar) and attach to another machine ....
Switch off completetly, unplug from mains, leave for a minute or two. Ten open up the machine and remove the CMOS battery (usually a 2032 coin cell) .... leave a few minutes, then replace the battery and fire back up again. You may something to the effect of "BIOS defaults used" ..... set the time and date and see how you go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundchippy Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2011 at 10:27pm
slaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slaz Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2011 at 10:13pm
all fans appear to be working correctly. the machine is less than a year old.
the power button flashes about every 2 or 3 seconds when it tries to boot.
Sounds rather like the motherboard has fallen over in some way, but could also be memory, PSU ... all sorts.
Assuming desktop machine ... you might try :-
Switch off completely. Take out the mains IEC from the back, and leave it a few minutes.
If it shows signs of life after this, use boot menu (usually F12) and see if there a "Dell diagnostics" option. If so (attempt to) run it .... might give you some clues.
Otherwise, unless you're fairly used to solving these kinds of probs, invoke your warranty if applicable, or take it to a competent tech.
