  New Posts New Posts RSS Feed - FTH12 Tapped Horn
FTH12 Tapped Horn
 Post Reply Post Reply Page  123 8>
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Topic: FTH12 Tapped Horn
    Posted: 30 October 2011 at 1:12pm
Mentioned this a few times but only recently got round to doing any serious testing. Not claiming anything special just a tiny 12" Tapped Horn. Size is 550w x 370h x 455d
Much better performance than with the driver in a ported cab. Output is about 2.5db down on my THAM15's and it looses about 8hz on the bottom end.
Driver is the Celestion FTR12-4080HDX
Design is inspired by Martinsson's THAM15's which still put an enormous stupid grin on my face.
Tony
Edited by Tony Wilkes - 30 October 2011 at 2:44pm
cuivenion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cuivenion Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2011 at 1:41pm
How does it compare to your BMS double 12's tony?
help!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2011 at 1:49pm
The double 12's have the extension of the THAM15 and sound good up to 200hz, The tapped has  more output and sounds excellent when used 45-150hz, it is silly powerful for its size :)
Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote cuivenion Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2011 at 1:51pm
Just wondering why you haven't used one of your BMS 12" drivers for the tapped horn, are they not suited to that type of design.
help!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2011 at 1:55pm
As you say not suited, for this type of design a highish Fs is a big plus.
Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote cuivenion Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2011 at 1:55pm
Looks like a nice design by the way! Clap
help!!!!!!!!!!
login4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote login4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2011 at 2:17pm
very cute tony, should be nice and cheap to build too, do you plan to release the plans for peeps?
cheers
CELTIC SUBSONIC SOUND SYSTEMS
colint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colint Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2011 at 2:22pm
Look's like a nice compact cab Tony,  Now cue 3 pages of "what other driver's will work in this box"  LOL
soundchippy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundchippy Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2011 at 2:28pm
looks good. smaller than the mth30 and seems to go a little lower with same efficiency (is it 1w measurement?). will you post the plans?
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundchippy Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2011 at 2:29pm
is this small enough to get 2 cabs from 1 sheet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2011 at 2:30pm
cheers
Yes indeed, as soon as I have tidied up my drawing I will do a PDF.
Regarding other drivers, as long as they are pretty close to the T/S parameters they should work.
Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2011 at 2:38pm
No the measurements are not to a reference level. You have to ignore the simulated output level as well, the only way is to build and measure which is the only way I will ever do it.
From memory the path is longer than the MTH but I suspect that it will probably not be as efficient as it is a smaller box, there is no such thing as a free lunch.
Tony
