Ecler amps. |
Post Reply | Page 12> |
taurusty
Registered User Joined: 09 January 2007 Location: Jamaica Status: Offline Points: 473 |
Posted: 19 March 2012 at 9:53pm |
Thanks KEL.
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4949 |
Nothing really like an HC3200 inside, case looks a bit similar, the RCF are bipolar aren't thhey, the Ecler are mosfet.
North Staffordshire |
M4trix
Registered User Joined: 23 June 2009 Location: Croatia Status: Offline Points: 445 |
You don't need to be afraid. It doesn't mean that something bad will happen to your amplifier. Well, don't fix something that ain't broken . If that bothers you, take it to a service for dust cleaning. Edit: *bumpity bump* does someone have a service manual for Ecler DPA 1400? Edited by M4trix - 19 March 2012 at 4:53pm |
taurusty
Can u say if the topology is similar to RCF HC 3200 (they kinda look similar)? I have one that has never been cleaned/serviced all these years & still going strong. U making me start to fret! |
M4trix
*bump*
M4trix
You got me there. Edit: speaking of which, do you have service manuals for DPA 1400? Thanks. Edited by M4trix - 17 March 2012 at 7:34pm |
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2582 |
those pictures were actually made by me in 2006
http://www.facebook.com/nexus.acoustics.research Ex Nexus_3 |
M4trix
Yes, much better design. |
Mircea Bartic
these were the ancestors of the DPA series
I Have't used PAM series as they were already discontinued in 2005 when we started selling them but the DPA models were built like a tank we have a lot of installs with DPA Amps running in bridge mono configuration runing 4 ohm subs for 7 years now , none have failed so far. Most of them are used every night in anger with no cleaning since we installed them (cheap managers) |
kedwardsleisure
Well they are rather old hence what I said about servicing.
major_gloom
Registered User Joined: 06 February 2006 Status: Offline Points: 196 |
i see. no wonder it doesnt like going down to 2 ohms if your effectively running each channel permanently bridged. not many amps would cope with 2 ohms bridged. i get the impression they're pretty power hungry too.
major_gloom
they certainly are heavy , and i must admit i did find them a little gutless on bass which is why i started this thread, i wondered if other people had found this.
i chatted to my mate who i borrowed a couple off and owns several of these. a channel has gone down on two of his and another 2 have died completely. so im thinking they're not the greatest amps.
