  New Posts New Posts RSS Feed - THAM 12 - a compact 12" TH
 Post Reply Post Reply Page  123 11>
geritass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geritass Quote  Post ReplyReply Direct Link To This Post Topic: THAM 12 - a compact 12" TH
    Posted: 12 September 2019 at 12:54am
Hi everyone, it will work OK, like B&C 12ndl76 ?
  • Skar Audio DDX-12 D2 - 12" Component Car Subwoofer
  • Dual 2 Ohm Voice Coil Configuration
  • Peak Power: 1,500 Watts
  • RMS Power: 1,000 Watts
  • Competition Grade Pressed Paper Cone
  • Stitched High Roll Foam Surround
  • Advanced Air Flow Cooling System
  • 2.5" High Temperature Copper Voice Coil
  • Motor Weight: 202 oz
  • Frequency Response: 25 - 250 Hz
  • Sensitivity: 88.0 dB
  • Fs: 33.8 Hz
  • Re: 3.9 Ohms
  • Qms: 4.1
  • Qes: 0.37
  • Qts: 0.34
  • Nref: .40 %
  • Cms: 0.07 mm/N
  • Bl: 25.5 n/a
  • Vas: 24.8 L
  • Mms: 243 gr
  • Sd: 510 cm^2
  • Xmax: 15 mm
  • Thanks in advancce
Hi everybody
Post Options Post Options   Thanks (0) Thanks(0)   Quote geritass Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2019 at 12:51am
Hi everyone, will work  Ok?
Thiele small:
  • Fs: 33.8 Hz
  • Re: 3.9 Ohms
  • Qms: 4.1
  • Qes: 0.37
  • Qts: 0.34
  • Nref: .40 %
  • Cms: 0.07 mm/N
  • Bl: 25.5 n/a
  • Vas: 24.8 L
  • Mms: 243 gr
  • Sd: 510 cm^2
  • Xmax: 15 mm
THANKS IN ADVANCE.
Hi everybody
wakemasia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakemasia Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 2:19am
Thank you very much for this awesome desing, martinsson! I just finished building them and am already amazed by these little beasts.
Here are a couple of pictures https://forum.speakerplans.com/tham12-custom-amplifier-build_topic103754.html
Thanks again!
Cheers from middle europe
guyfeld View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote guyfeld Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2017 at 7:34am
Originally posted by JOEDL1509 JOEDL1509 wrote:
good day all,
Please can someone help me with a cutting list for the THAM12
In 2013 I built a pair of THAM12's & loaded it with the Faital Pro 12HP1010 & fed them with an iNuke6000. They are used for mobile disco application...were intended for smaller functions but they have been performing so well I actually have used them for bigger gigs as well. I honestly have shocked many a sound junkies with the compactness and sound output with these small little buggers.
I now bought another pair of 12HP1010's so for bigger gigs I will use all 4 THAM's. However I seem to have lost my original cutting list.
I am only able to get 18mm ply, so please can someone help me with a cutting list for the THAM12's
Hey there, I just joined the forum and saw your old post. I'm also in S Africa but in C Town area. I've been thinking of Replacing my DB technologies sub15d active sub and building at least one Tham12 with the faital 12hp1010 which is on a special at the moment for around R2800. (powered by a Synq 1k0 100w amp)
You are using yours for DJ? I am a Live performance solo musician(gtr, kbds, vox, backtrax) and am looking at a single compact 12 sub carryable with one hand. How much does yours weigh? Also, how high does it go without sounding bad..150hz?Would you say the response is smooth enough? Do you find you need to use dsp like a Behringer deq2496?
And the wood thickness..did you go for 18mm/15mm? Did you use birch or pine ply?
Did you manage to get a cutting list?
Thank in advanceSmile
JOEDL1509 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JOEDL1509 Quote  Post ReplyReply Direct Link To This Post Posted: 01 November 2016 at 12:12pm
good day all,
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2016 at 3:44pm
Yes probably that's true, it's not muich of a horn driver actually in the usual way, try a sim:-)
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2016 at 2:58pm
the lab 12.... my reply speed was so sloow it jumped a few posts and looked random lol.
he said the lab12 was a no go and utter s##t.
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2016 at 10:50am
Fane 12xb has great perfomance in there, why would you "ignore efficiency"
If you want to play loud it's all about efficiency.
Raw power by WATTS will distort & blow your speaker at the end of the day
Originally posted by mini-mad mini-mad wrote:
I think Anders said it was a no go....
What is a no-go? Using different drivers?
Don't know what the new-christian drivers puritanism in here is aboutClap
-But I know he suggested several drivers and are open to this.
Yet you might refer to something copletely different?
Chendy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chendy Quote  Post ReplyReply Direct Link To This Post Posted: 02 October 2016 at 5:40pm
Which driver has the best performance?
Im looking http://www.martinsson.cc/blog/index.php?entry=THAM12 - here at the list of simulated drivers, but can anybody recommend any which might have the best performance (ignoring efficiency). Want max SPL, with good frequency response, quality etc etc. I have access to large amps, so which driver will allow me to squeeze as much as possible out of these little subs
thanks
Sapro2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sapro2 Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2015 at 8:30am
Ok, thanks guys. I will have a play with hornresp though
Splat Soundsystem
Baby Sham pram Soundsystem
Sapro - SoundCloud
https://soundcloud.com/sapro
DJ Sapro. West country free party DJ and Producer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2015 at 9:25pm
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2015 at 8:17pm
I use the help file, I think it's great:-)
But Google it & it:-) See:
http://www.hometheatershack.com/forums/diy-subwoofers-general-discussion/36532-hornresp-dum-hmm-everyone.html
https://www.freespeakerplans.com/forum/8-advanced-discussion/8687-horn-resp-for-beginners?start=10
http://www.avsforum.com/forum/155-diy-speakers-subs/1212465-simple-tapped-horn-tutorial-using-hornresp.html
Ok basically first section is 2 pi (free on ground) 2,83V (1watt) (or use 1 pi to compare to 1pi sims)
Next section is how area increases by hornsectionlength, copy-paste that from tham12 simulation.
Next section is speaker specs, read specsheet, fill out what you can first, double-click other fields to make hornresp calculate for you, then it will ask for Fs, Qes etc.
Last section is rear/front chamber, copy past from tham12-in this case all zero I guess.
Edited by tv00 - 01 December 2015 at 8:21pm
