  New Posts New Posts RSS Feed - MT121 Drivers...
MT121 Drivers...
 Post Reply Post Reply Page  123 10>
sushi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sushi Quote  Post ReplyReply Direct Link To This Post Topic: MT121 Drivers...
    Posted: 02 July 2021 at 4:17pm
Hello! Me and my workmate just built a pair MT121 (original two section mid horn, not TDA's) now we are looking for suited loudspeakers to fit in. I've already got 2 brand new beyma 12MI100 i would definitely like to try for the mids.. anyone has heard them in this kind of cabs?
For the high band i was looking for a horn with low cutoff, since i read from other forum members this horn design has to be crossed below 1khz. I saw the beyma TD-365 horn (800hz cutoff) and the CD-1114F1E that look fine on paper but never heard them. What do you think about it?
Any advice welcome!
Cheers
Risc_Terilia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Risc_Terilia Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 7:44am
Originally posted by Risc_Terilia Risc_Terilia wrote:
I was looking at the Beyma 12p80nd for my cabs.  They have an additional 6" horn between the 12 and a 1 which I crossover at 500hz.  I've realised that this Beyma driver would be pretty wasted in this application so I'm wondering what a good driver for an MT121 12 horn would be if I'm only running that horn 160 - 500 hz.  I'm after high efficiency and power handling - don't mind spending a bit of money on them.
Cheers
Edit: B&C 12FW76 looks good:  100db sensitivity and still high in my pass band, 500w, BL 26 JUST about fits in the chamber.
Got a pair of 12p80nds, rrallr excited to see how they sound.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Risc_Terilia Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2018 at 10:26am
Cheers
Edited by Risc_Terilia - 08 February 2018 at 12:54pm
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2017 at 7:20pm
FAQ in the main site has a good bit about drivers for midrange horns. And the mt12 horn was designed originally for the pd123er, so that's a starting point for choosing drivers for it.
_Natty_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2017 at 6:03pm
13 pe32 is almost out of stock and b&c would leave it... they suggest me 12mh32 but sims give me back shitty spl graph...what spec we have to watch to for a proper mid? What is the first thing to mods for adapt a project like that? Horns mouthaybe?
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2017 at 4:32pm
^ not really imo.. you want a proper mid driver in such cabs like b&c pe32 for example..
DJ123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ123 Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 12:38am
will the B&C 12NDL88 work good in this cabinet ?
B&C 12NDL88
12NDL88
  • New 12" High Power Mid-Bass & Bass Speaker
  • Lightweight Neodymium Magnet
  • 8 Ohms - 98dB SPL
  • 700 Watts AES Standard
  • 1,400 Watts Program
  • 50Hz - 3.0kHz
  • Large 3.5" Voice Coil
  • High Xmax of 8.0mm
  • Weighs Only 8.6 lbs.
  • Waterproof Front & Back Cone For Outdoor Use
  • Double Spider
  • Clean Mids & Strong Tight Bass!
UpComingSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2012 at 8:22pm
I purchase the celestion TF1225E they sound pretty good didnt put to much power thru them yet but sound pretty good, for the price
bitSmasher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitSmasher Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2012 at 7:51am
I believe the 12" Black Widow had similar enough TS specs to match the SN12MB, since they're so cheap in the USA it'd be worth looking in to
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Posted: 18 August 2012 at 4:05pm
what about the peavey black widow 12 inch for midbass
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2012 at 9:46pm
its a very nice mid bass speaker....
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2012 at 9:45pm
